It is currently Wed May 20, 2026 10:24 am
 Post subject: 225 parts in a 170
PostPosted: Fri Aug 15, 2008 7:32 pm
i have a 64 valiant with what i was told was a 225. I was having some timing issues and a cam lobe was going down so i ordered a new cam and timing set. Once i got the head off something didn't look right and when i measured the stroke, sure enough its a 170. the problem is that i already have the parts that are for the 225. Will they work in the 170? thanks
1964 Plymouth Valiant 4 door V200
170 slant six
1996 Dodge Dakota 318
1953 Willys Pickup-= V8 Conversion project
PostPosted: Fri Aug 15, 2008 7:35 pm
Cam and timing set will interchange. Pushrods would be different if you got those.
PostPosted: Fri Aug 15, 2008 7:46 pm
Lots of 170 and 225 stuff is common. It's probably easier to list what won't interchange. Block, crank, rods, pushrods.
PostPosted: Fri Aug 15, 2008 8:12 pm
Online
With a 170 make sure to check the valve to piston clearence, if installing a bigger cam, and milling the head.
Users browsing this forum: Ahrefs [Bot] and 12 guests
