It is currently Thu May 14, 2026 9:03 pm
 Post subject: broken choke stove bolts
PostPosted: Mon Aug 18, 2008 6:37 pm
does anyone have a source on the web for choke stove bolts?
PostPosted: Mon Aug 18, 2008 10:16 pm
Plain ol' ordinary hardware store items.
PostPosted: Tue Aug 19, 2008 12:03 am
yep old hardware store parts bin, i have even boken a few off and drilled / tapped em out to a slightly bigger size, and replaced with grade 8 hardware store ones.
PostPosted: Tue Aug 19, 2008 12:15 am
PS, buy one of the Electric choke kits and you'll only need one bolt, the "rear" one closest to the cylinder head...unless you have a '70-'72 exhaust manifold, in which case you must use two bolts at this location to avoid an exhaust leak.
PostPosted: Tue Aug 19, 2008 9:01 am
Or get a manual choke..
PostPosted: Tue Aug 19, 2008 3:38 pm
the original choke stove bolts were stainless steel which were far less likely to seize in the cavities.
Users browsing this forum: Amazon [Bot], Google [Bot] and 10 guests
