It is currently Wed Jun 17, 2026 10:34 pm
 Post subject: Manifold Installation
PostPosted: Sat Dec 14, 2002 3:55 pm
Check out Doug's new article on manifold installation.
http://slantsix.org/articles/manifold-i ... unting.htm
Chuck Rivers, Webmaster
Image Image Image Image
PostPosted: Sun Dec 15, 2002 2:10 pm
good article, I still haven't managed to get the triangle washer on the last bolt(under the choke stove) It really irritates me as I don't even use the choke stove anymore. :) Manul choke lever for me... toomuch fiddle time with the other one. I tried the phillips method but couldn't get it too work as I couldn't get a second screwdrive in the space. I'l try the fishin line one, on Tuesday.
PostPosted: Tue Dec 17, 2002 10:53 am
I use a long screwdriver with a 3/16 shaft to position the washer and then use a 1/8" screwdriver to slide it on.
PostPosted: Mon Dec 23, 2002 10:58 pm
I just went from a one bbl to a 2 bbl this past weekend. Wow what a difference it makes. The way I got the bottom washer on under the choke stove was like this: I cleand off a small spot on the triangle washer, put a small drop of super glue on the clean spot, line up and put on the nut, let dry, and put it in the socket. Worked like a charm. Try that.
PostPosted: Tue Dec 24, 2002 5:10 am
i use one of those little telescoping magnets hardware stores sell for like 3 bucks. just stick it on one side of the washer and guide it onthe stud (keep away from manifold runners!) they also work well for picking up dropped hardware (see murphy's law! :roll: )
-james
PostPosted: Thu Jan 16, 2003 3:06 pm
I use the telescoping magnet method as well..but i do (well, used to....headers make things lots easier :D ) it from the top. I.E. Guide the washer on from between the manifold runners which leaves the side open to get a ratchet w/ extension and wobbly in there.
oh yeah--the magnet makes picking up the dropped washers easy too :roll:
-Aaron
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot] and 2 guests
