It is currently Mon Nov 23, 2026 9:13 am
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
PostPosted: Mon Aug 25, 2008 12:34 pm
Ed, where did you get your carpet, pad?
It was from Pep Boys for another project which I never got around too...........
But Pep Boys doesn't have it anymore :cry:
I think this stuff would work (might need to double up or add carpet backing):
http://www.lowes.com/lowes/lkn?action=p ... lpage=none
There's various size rolls of the same stuff.
PostPosted: Mon Aug 25, 2008 2:39 pm
No, Ed, I meant "your carpet and your pad".
Did you sew the edges yourself?
PostPosted: Mon Aug 25, 2008 3:14 pm
1A auto on ebay sells the ACC carpets. They are made to order if you get a odd color but it only takes a couple of days. They dyed up one in fawnskin for my 65 Dart and it was perfect in fit and color. Colors from other shops usually cost more.
I have used ACC carpets in quite a few cars, they seem to be about the best and are what you would likely get from any of the better restoration sources.
PostPosted: Mon Aug 25, 2008 3:36 pm
Well, good luck on the pad since Pep Boys doesn't have it anymore.....
As for the carpet, I got it at a local upholstery shop from a roll they had in the back (and they don't have it anymore either as I found out when I made some matching floor mats). The carpet for the floor mats was something I found on the internet. (they'll send you samples, so I was able to match what I had)
No sewing. I laid the carpet in sections and glued it down. Edges that aren't seen (under seats, under carpet, under sills) was just melted with a butane lighter so it wouldn't unravel.
The one section that is seen (front by the tranny hump), I melted the edge, then folded it back on itself about a 1/2" and contact cemented it and clamped it between 2x4s until it dryed. It gave a nice straight line (as compared to the melted unseen edges) and reinforced the edge as well. So the seam is visible, but pretty neat.
PostPosted: Mon Aug 25, 2008 9:13 pm
Hey Ed, how did you make the folds in the corners stay neat. Are they glued down with something?
Danny
PostPosted: Mon Aug 25, 2008 9:21 pm
Danny
The carpet pad is contact cemented to the floor, the carpet contact cemented to the pad.
Did it slowly, a section at a time......... with lots of weight, let dry, more glue.......
PostPosted: Tue Aug 26, 2008 7:58 am
Well, you did a great job. My next step is local Upolstery shops and carpet outlets.
I really think I'm going to have to do what you did with this 4-speed hump issue.
Looks GREAT Ed.
Thx
PostPosted: Tue Aug 26, 2008 10:34 pm
You also might try here: Trim Parts in Lebanon, OH. They have distributors all over the country. You can especially get a good deal on their products if you can catch them at a car show/swap meet.
(513) 934-0815
sales@trimparts.com
Jerry
