It is currently Fri Nov 13, 2026 9:44 pm
 Post subject: Msd6a
PostPosted: Fri Aug 29, 2008 10:04 am
My dad just sent me a MSD6A. Is this worth the install time? Do I need an eletronic alt and a new coil (the gift that keeps on giving???)? What gains can I expect?
Thanks for the help!
slanted66
PostPosted: Fri Aug 29, 2008 11:36 am
The MSD6A is a good ignition system (though their reliability record hasn't been as good as one would hope for the money). What're you running now? Points? Chrysler electronic?
PostPosted: Fri Aug 29, 2008 1:34 pm
Dan,
I have the stock poins in it now.
Thanks!
PostPosted: Fri Aug 29, 2008 2:05 pm
Well, you'd need an electronic distributor to run the MSD6A (or any other electronic system — Mopar EI, HEI, etc.) so if you're up for getting away from the points, and an MSD6A has landed in your lap, you're that much ahead!
You can get a brand new electronic distributor from Old Car Parts Northwest.
PostPosted: Fri Aug 29, 2008 3:02 pm
Actually, you can use the white wire on the MSD box to trigger from the points distributor. The MSD will give you better sparks and the points will last longer, but you still have to set the point gap once in a while and reset the timing which you would not have to do with an electronic distributor.
PostPosted: Fri Aug 29, 2008 3:26 pm
H'mm. I had thought the MSD 5 was suitable for points triggering, but not the MSD 6.
PostPosted: Fri Aug 29, 2008 3:34 pm
Dan, RTFM (read the............)
http://www.msdignition.com/uploadedFile ... t/WDTN.PDF
:lol: :lol: :lol:
PostPosted: Tue Sep 02, 2008 7:36 am
Thanks for your help guys!!
PostPosted: Wed Nov 26, 2008 9:47 am
I run my old v-dub with points on an MSD6a. Cured my weak spark problems when I'm on boost.
________
marijuana indica
