It is currently Thu Jul 16, 2026 10:30 pm
 Post subject: 2 barrel from a 1 barrel
PostPosted: Sun Jan 19, 2003 4:24 pm
I got a carter 2 barrel off a van today for $43.00 w/alum. intake.My main question is how I hook up the throttle linkage?My cars a 63 dart w/ the steel rod linkage.This carb. has linkage on the inside toward the engine.should I convert to a cable type linkage?......And will i need a bigger exaust pipe?.........If anyone has done this before i'd appreciate some ideas.......thanx,6boy..... :wink:
PostPosted: Sun Jan 19, 2003 11:09 pm
You will need to find the cable throttle linkage, look for one off a V8 or a Supersix in a passanger car.
Did you get the exhaust manifold with the 2 bbl intake?
Your exhaust pipe will bolt-up to either manifold but the choke stove and linkage is different.
<img src="http://www.dutra.org/doug/doug-sl6-exhaust/2bbl-dual.jpg"width=400>
PostPosted: Tue Jan 21, 2003 6:40 am
thanx for the help Doc!!! I also have a auto tranny w\the rod type linkage.You think i'll need to change somthin there?
PostPosted: Tue Jan 21, 2003 5:48 pm
oh yeah, no i did'nt get the exaust manifold.i was short on cash.(as always)i dont use the choke now anyways.i just let it warm up real good before takin off.i am goin back for the air cleaner as mine wont fit.i hope its still there.i'll try to get the ex.manifold as long as long as i dont see any cracks!...later,6boy.....
 Post subject: Super Six
PostPosted: Wed Jan 22, 2003 5:30 pm
What you got was a Super Six manifold and carb setup. I'm planning on doing the same upgrade to my 63 Dart 270 convert at some point. In the engine forum there is a lot of information about doing this upgrade. Just do a search on Super Six. I also found a good article on doing the conversion at:
www.geocities.com/motorcity/track/2525/supersix.html
With your automatic trans you'll also need the kickdown linkage. Apparently, you'll have to bend it some to get it to fit but it should work. That is, unless the truck you got it from has a different linkage. Anyone else know if it will work on his car?
Also, I read somewhere that you should paint your aluminum intake with a good heat resistant paint. The aluminum can sometimes be porous.
Nick
PostPosted: Thu Jan 23, 2003 6:36 am
cool,we got the same car Nick.I'll let you know how this goes this weekend......later,6boy..... :lol:
PostPosted: Thu Jan 23, 2003 6:38 am
oh,mine aint no convertable! :D
