It is currently Fri Nov 27, 2026 2:58 pm
Post new topic  Reply to topic  [ 91 posts ]  Go to page Previous 1 2 3 4 5 … 7 Next
PostPosted: Thu Sep 25, 2008 2:09 pm
Poser
Dang it all!
PostPosted: Thu Sep 25, 2008 2:34 pm
All right SlantSixDan, the suspense is killin' me! What other interesting things are you Talking about?
I don't wanna jinx it. Sorry, but a teaser's the best I can do at the moment.
Sounds like the aluminum head idea again :roll: :wink:
Nope, that's not it. And no, it's not repro aluminum blocks, either.
PostPosted: Thu Sep 25, 2008 2:35 pm
what can of shipping cost are we looking at? I'd love to have a 4-barrel intake.
PostPosted: Thu Sep 25, 2008 6:38 pm
Poser
No hints! Dan this is worse than an Alfred Hitchcock movie. :?
PostPosted: Thu Sep 25, 2008 7:59 pm
Send me your detials
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Fri Sep 26, 2008 7:44 am
Please use this present thread for discussion about the manifolds themselves.
Orders for these manifolds (and shipping info, etc.) are now being collected and organised in a separate thread in the "Parts For Sale" section.
PostPosted: Fri Sep 26, 2008 10:50 am
It looks like there isnt enough room for a 4bbl on the one I like. I dont see how one would mount. What carb was used stock for it. how would a holley/demon work on it and for the record a 2bbl addapter is still a good idea.
it's like a vw, sounds like a million miles an hour but goes really slow. (for now)
PostPosted: Fri Sep 26, 2008 11:29 am
Originally they used a 400 cfm Carter AFB - small form factor - the pattern is being adjusted to allow the installation of a 4150/60 type Holley 4BBl in size with the correct adapter plate - the 4BBL is being modified internally for better mixture control
Hope this answers your question :D
Regards,
Fanie Gerber
PostPosted: Fri Sep 26, 2008 11:31 am
Got a picture of one these 400cfm Carters?
PostPosted: Fri Sep 26, 2008 11:41 am
Unfortunately not , but i have one waiting to be sent to me :D
This is the adapter I use to run a 4150 on another RSA 4BBL Manifold that was only intended for for the AFB
http://www.tdperformance.com/images/?id=5465
It uses the inner bolt holes to the manifold, and the outer ones to the carb hope this helps
Regards,
Fanie Gerber
PostPosted: Fri Sep 26, 2008 10:00 pm
Hi Guys,
I had requests for lnkage kits and adapters which would allow the fitment of BBS Carbs
Not a problem - linkage kit will be completed over this week end -
I Changed the kits design to make it more sturdy and and adaptable to different carb setups -
Regards,
Fanie Gerber
PostPosted: Fri Sep 26, 2008 10:14 pm
The killer for the clifford hyper pak intake is the fact that even without the use of an adaptor, you either have to find a drop base air cleaner, run an air cleaner that has a narrow air filter element (2"), or cut the hood...
even if you cut 6" of length off it, you still have problems with spacing of the air cleaner as compared to the ribs reinforcing the hood...
So why aren't they machined with a carb pattern like the older clifford hpaks (the original jig Doc has for carb stud holes), so buyers can gain back that extra 1/2" the carb adaptor steals with the limited hood clearance... (that if you use a short ram(Offy), it puts the air cleaner in the stock location where there is lots of room for a taller/stock air cleaner???
Just Curious-
PostPosted: Sat Sep 27, 2008 8:35 am
Would that include a divided plenum with the carb rotated 90 degrees compared to the usual V8 mounting, by any chance? Just wondering as that intake looks like it might be a good candidate for that.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Sat Sep 27, 2008 9:46 am
Mat YOU my man have it all in one and if you guys look at the comparison with a cast iron supersix equivalent circa 1968 :D - export slantsix -You will see the carb is not that far from stock position :
Oh and a 2 x 2 long ram comparison
Regards,
Fanie Gerber
PostPosted: Sat Sep 27, 2008 10:22 am
It wasn't about linkage issues - I was kind of wondering with the odd runners branching off the ends of the plenum layout if a split plenum may have better fuel distribution than an undivided one.
Users browsing this forum: Ahrefs [Bot] and 5 guests
