It is currently Fri Nov 13, 2026 3:40 am
PostPosted: Thu Oct 16, 2008 6:39 am
Runs I figured I would start a comment thread.
:D :D :D
Looks Great.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Thu Oct 16, 2008 12:04 pm
Thanks, nice to know my time isn't wasted. Hope it can help someone!
 Post subject: any updates?
PostPosted: Wed Aug 26, 2009 5:36 am
this thread hasn't been updated since oct 2008.
how is the megasquirt coming along? i am doing research for a turbo /6 build and think i'd like to try megasquirt when the time comes.
PostPosted: Sun Aug 30, 2009 10:49 am
I have Megasquirt 'n Spark extra running an EDIS coil pack on my Barracuda now. I will do the fuel injection next.
At least for ignition, this isn't a hard modification to do. The hardest part was getting the 36-1 wheel mounted ( and that turned out to be easier than I thought), and welding up a VR sensor bracket.
 Post subject: EDIS details
PostPosted: Sun Aug 30, 2009 8:17 pm
I am thinking of trying the EDIS also. Where did you mount the 36-1 wheel? In front or in back of the pulley? Do you have a damper on the crank?
I assume the EDIS was from a 4.0 V6. Can you adapt the wheel from the 4.0 or or do you have to use an aftermarket wheel? {i was wondereing if the 4.0 was an even fire motor or an odd-fire}
How about the coil packs? how many
[sorry bout all the questions]
1979 W150 Shortbox
225, NP435, 9 1/4, Dana 44
The Good Life.
PostPosted: Sun Aug 30, 2009 9:33 pm
So, I used a 4.0 V6 EDIS box, as you predicted. I have a 1965 slant, with two crank pulleys. I removed the front pulley, as I wasn't using it anyway, and mounted the metal 36-1 wheel to the rear pulley.
There are a bunch of places that make those wheels, (DIYAutotune being one). You need to drill out the center hole to fit the crank bolt. I used the existing 3 bolts that hole the front pulley to the back pulley to locate and mount the wheel correctly.
Mount fabbing-- :shock:
You need a mig welder. I cut up a few pieces of metal, and used the two oil pan bolts more or less at the bottom of the motor, and built a U shaped bracket that went to the front of the motor.
Coil packs- Just use the one coil pack on the 4.0 donor.
Both motors are even fire motors. You just need to translate the firing order from the ford to your slant, and it works.
PostPosted: Mon Aug 31, 2009 10:05 pm
Thanks for reply.
should not be a problem fabbing the mount [I got 2 chop saws!] LOL
1979 W150 Shortbox
The Good Life.
PostPosted: Tue Sep 01, 2009 8:41 pm
Cars been running great, had no questions about anything. I haven't done the Ford ignition system yet, but we are planning for the next motor. In fact with all the new casting we've been doing I really want to get rid of the distributor and make very basic light block.
PostPosted: Wed Jan 06, 2010 1:32 pm
Greg, This Is what I wanted to do this summer with my volare duster But the Ruster Project got in the way. I have the Coils and 36-1 wheel and everything to goo Just need some wrenchin time now.
Any pics of your stuff?
