It is currently Fri Nov 27, 2026 3:05 pm
Post new topic  Reply to topic  [ 91 posts ]  Go to page Previous 1 2 3 4 5 6 7 Next
PostPosted: Sat Sep 27, 2008 10:37 am
I would say so plus better torque characteristics - this thing has a HUGE plenum -
We are changing that aspect slightly to allow each three runners equal access to mixture and to straighten out the flow from the manifold
The Idea is to keep to the weird look with better flow
Why I referred to the position of the carb was Zilla's question regarding air cleaner location
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Sun Sep 28, 2008 5:17 am
That was DI, I'm just watching here. :D
PostPosted: Sun Sep 28, 2008 10:02 am
oops :oops:
Regards,
Fanie Gerber
PostPosted: Fri Oct 03, 2008 4:56 pm
well instead of the side draft weber 6-pack, how about a carter 2bbl 6pack (3X 2bbls) ? 225 6pack has such a nice ring to it ...... :D
-Mike
 Post subject: Manifold
PostPosted: Thu Oct 09, 2008 11:00 pm
Car Model: 64 Valiant Convertible, 64 Valiant 2dr Post, 64 va
Count me in for a long runner dual manifold. Tell me when to send the cash.
Thanks for all the work
RJ
 Post subject: Update
PostPosted: Fri Oct 17, 2008 5:05 am
The longram Pattern - EFI bungs included are done - Unfortunately no pics yet - and I am of to Europe for two weeks......cant decide if I should look forward or not :?
The moment I am back I will post the pics and the long awaited pricing on the aircleaner/linkage set
Later
Fanie
Regards,
Fanie Gerber
PostPosted: Sun Nov 09, 2008 8:34 am
LO :D :D
Well just before the pattern was made up I went through prerequisite's
Injector bungs - DONE
Water heated Plenum -DONE - BTW this will be cast in with heater hose sized nipple's - stainless if You wondered and fins This box is about the same size in area as the stock manifold heat box and about one inch high
Linkage kit - DONE at the platers as we speak - having it chromed
This last change came about due to Dans' comment about the Ozzie bolt on type - I now have TWO patterns one original and one mod 8)
Gents I know most of you have sent your details - those who did not or who still wants to order please let me have your info.
As I stated earlier - a paypal account has been set up. you do not need to go through ebay to use this - if you have a paypal account that will do
Western union is also an option
Fanie
Regards,
Fanie Gerber
PostPosted: Sun Nov 09, 2008 10:11 am
"Ozzie bolt-on type"...? :shrug: I was talking about the U.S./Canada/rest-of-LHD-world rotating-rod throttle linkage used from '60-'66. I think rotating-rod arrangements might've been used in some form in Australia on the early cars (maybe up through the AP6 or the VC model) but I'm not certain...what'd you use for a pattern?
PostPosted: Sun Nov 09, 2008 10:35 am
Glad to hear about the progress! Keep it up, Fanie, and let us know when the alloy cools on the first batch...
PostPosted: Sun Nov 09, 2008 11:05 am
AAAARGGGGGHHHHHH CONFUSION!! :lol:
OK The Ozzie speed Hurricane has a BOLT-on water Heated arangement.
Mine is cast-in - truth be told it was easier to make than a seperate loose box :D AND I am scared of Air leaks or the possibility there of
NOW I am going to shock you!!!
I have three of the original manifolds 8)
The one with the most external nick's etc was wire cut (Wire abraded) along the casting line to separate the halves and get the core shape.
Only lost 0.4mm material for those who was wondering.
The cost of having the pattern made the usual way ~ R30000 - this way R8000
One is being used as an original pattern and one for mod . Cool heh?
Regards,
Fanie Gerber
PostPosted: Sun Nov 09, 2008 12:13 pm
Ohhh! You're talking about manifold heat, and I thought you were on about linkage! :oops:
Wow, that is really impressive!
A little shy of $800 American...pretty durn reasonable given the amount of work involved, I think!
PostPosted: Sun Nov 09, 2008 12:27 pm
WHAT no BURNING PENTASTARS on my lawn for sacrificing a manifold
UNbelievable :shock:
Regards,
Fanie Gerber
PostPosted: Mon Nov 10, 2008 3:19 am
Have to sacrifice to make progress. Heck, you'll be improving on the original design, so I for one applaud your efforts.
 Post subject: longrunner 2x2 on ebay
PostPosted: Tue Nov 18, 2008 2:46 pm
did anyone else see the longrunner 2x2 on ebay a couple days ago? the title description also stated it was used on south african police cars. the seller location was australia and had zero previous sales.
PostPosted: Tue Nov 18, 2008 2:49 pm
Seller location was South Africa, not Australia. Those are these very intakes we're discussing right here in this thread now. See this other thread if you'd like to loop around in circles. :-)
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 8 guests
