It is currently Fri May 08, 2026 1:41 pm
PostPosted: Tue Oct 21, 2008 5:43 pm
I'm almost done with my disc brake conversion and need some advice.
So the rim spoke is just rubbing the caliper (cragars :D yay). I am using washers as a gauge for the rim spacer size I need, I want to keep the spacer as small as possible.
What is the minimum space I should have between the caliper and spoke?
Is 1/8" to little?
PostPosted: Tue Oct 21, 2008 6:47 pm
I had to grind the calipers on the rear of the Valaint to clear the rims....its not unusual.
As long as they clear it doesnt matter how much.
PostPosted: Wed Oct 22, 2008 7:08 am
Thanks, that is what I needed to know. 8) My only concern was that the area on the caliper that needs grinding are the cast "supporting ribs" on the stationary side.
PostPosted: Thu Oct 23, 2008 10:33 am
Be sure to measure with a new outboard pad. As it wears, you'll get even more clearance.
O==\=/==O
"A mechanic is Somebody."
- Jim Preston
