It is currently Thu Jan 01, 2026 6:40 pm
PostPosted: Sat Nov 01, 2008 9:40 am
Hi all,
Can someone tell me where the cork gasket (on the right side in the pic below) goes? It is part of a gasket kit, Sealed Power #2601004. I'd appreciate any suggestions, thanks!
Roger
Image[/img]
PostPosted: Sat Nov 01, 2008 10:03 am
Oil fill cap gasket?
PostPosted: Sat Nov 01, 2008 10:44 am
Thanks, I hadn't thought of that. I just checked and it doesn't fit my cap, but mine's a '67. This same gasket kit is used for multiple years - maybe a later year cap might use it? Anybody know for sure?
PostPosted: Sat Nov 01, 2008 10:51 am
'70-up cars did use a cap with a gasket that might've been kinda close to those dimensions, but this what you're showing us looks to be too large, too thick, and not the right material for an oil cap gasket; I don't think that's what it is. But I can't say what it actually is, either! :shock:
(it's a "pocket gasket" — when the engine's all put back together, starts and runs, has good oil pressure and doesn't leak any fluids, you put this gasket in your pocket and call the job done! :lol:)
PostPosted: Sat Nov 01, 2008 3:19 pm
i have seen it in all the re-ring kits i have but it doesn`t fit any where i see ? :?
PostPosted: Sat Nov 01, 2008 7:24 pm
Car Model: 87 B150, 1970 Valiant 4-door
there is a gasket like that between the fill tube of a slant van and the valve cover.
I've been unable to find it listed as a part anywhere, and as such have contemplated buying a whole car/pickup oil cap just to harvest the gasket (operating under the assumption that the gasket would be the same).
PostPosted: Sat Nov 01, 2008 7:41 pm
Ed,the fill tube on my 83 van has a "neorubberpren" gasket not the corkish like one in the picture.However I've got a 318 out in the bone pile that has a cork gasket on the fill cap so who knows :?
PostPosted: Sat Nov 01, 2008 10:09 pm
The fel pro 225 1960/80, 170, 198,1961/74 gasket sets I have calls it a head cover (valve cover) filler pipe gasket part# 70354, but is not specific as to which "cars" it fits.
63 Dart Convert. 39 Plymouth Hotrod Hemi, Cushman scooters,
PostPosted: Sat Nov 01, 2008 10:30 pm
Dang. I was going to say its the domahicky for the whatzit.... :wink:
PostPosted: Sun Nov 02, 2008 7:22 am
Fab64,
I'll buy it from you (unless it holds some sentimental signifigance for you) if you like.
I can't find one anywhere.
PostPosted: Sun Nov 02, 2008 7:38 am
Seal for muffler bearings, Only one on a slant because of only one muffler :lol:
'72 Duster 198 stock cam, 3:23's Hookers on jack stands for 8 years in the driveway
'79 Maxivan 360 Offy Qjet Comp RV cam/rusting in the driveway.
93 D350 160HP Cummins Auto :-( Dually Clubcab needs a injector pump
2005 Golden Couch Buick
PostPosted: Sun Nov 02, 2008 8:00 am
It could be for the old style oil filter-inside between the filter element a seat. But I don't know the dim. or if they used these in'67
sometimes they just throw in extra bits to cover a range of years.
PostPosted: Sun Nov 02, 2008 9:01 am
Fab64,
Ed,
Yes, I've become very attached to it - LOL!! I'm going to try calling Federal Mogul tomorrow to see if they can tell me. If it turns out I don't need it, it's yours for postage.
Roger
PostPosted: Tue Nov 04, 2008 5:36 am
Fab64,
I'm having trouble PM-ing. If you have six identical messages, I apologize. If you have none, please lmk.
thanks.
PostPosted: Tue Nov 04, 2008 10:39 am
It holds in the blinker fluid. :D
Users browsing this forum: Bing [Bot], Red and 5 guests
