It is currently Mon Jun 22, 2026 2:03 pm
 Post subject: Gas tank for 60 Valiant
PostPosted: Wed Nov 05, 2008 7:26 pm
Just like the title says,I need a tank for my 60 Val and was wondering if anyone has had any luck using a different year tank as 60-61 tanks are unique and not reproduced.My current tank is not only scummy and rusty on the inside but has been dented pretty badI have even considered a fuel cell but really dont want to go that route.
Is a 63 tank close enough to fit or will it not fit due to the non typical shape of the 60-61 trunk floor?
Has anyone else had this problem and what was your solution?
As always any help is greatly appreciated.
Thanks
HyperValiant
PostPosted: Thu Nov 06, 2008 9:50 am
Ooohboy. That is a toughie...I think this topic has come up before.
*search search search*
Yep, it's over here.
It'd be nice if someone would repro the '60-'61 and/or '62 tanks. As it stands, an exotic replacement such as a custom fuel cell might be about the only way to have a new one...
PostPosted: Thu Nov 06, 2008 10:53 am
Online
Awww, what's wrong with air shocks, leaf spring extension shackles, and a 55 gallon drum? :wink:
 Post subject: 60 fuel tank
PostPosted: Fri Nov 07, 2008 4:55 am
if you decide to go later style route I have a nice used 66 dart tank/sender you could have for shipping, Lawrence
PostPosted: Fri Nov 07, 2008 7:23 pm
Thanks for the replys ,I may try to straighten the dent and line the tank.
I would really hate to modify the trunk floor but I may have to and run a 63 tank.Once again ,thanks for the replys.
HyperValiant
