It is currently Mon Nov 23, 2026 12:30 pm
 Post subject: Is this good voltage ?
PostPosted: Sat Nov 08, 2008 12:38 pm
I am working on putting on the Hei and coil relay (Thanks Dan!)
and I wanted to check the voltage first. With the key on , the votage to battery is 12.59V and alternator was 12.36V . With the engine running the battery shows 14.05V and the alternator shows 14.36V.
Thanks
Dave
81 Dodge D150
It looked easier in the book .
PostPosted: Sat Nov 08, 2008 12:44 pm
Voltage at the battery with engine off looks good.
Voltage at the alternator with the engine on looks good.
Does the ammeter on your dashboard work? If not — and I'm guessing probably not; they're a weak design — run a 10ga wire from your alternator B+ (output) terminal to the battery positive terminal to reduce the voltage drop between the alternator and the battery.
PostPosted: Sat Nov 08, 2008 12:58 pm
Yes the ammeter does work, it has a little movement, but barely.
If I do run the 10ga wire from battery to B+ alternator , do I disconnect the wire that is on the alternator B+ terminal now.
81 Dodge D150
PostPosted: Sat Nov 08, 2008 1:09 pm
Nope, don't disconnect any existing wires — just add the additional new one.
PostPosted: Sat Nov 08, 2008 9:23 pm
Don't forget to add a fusable link on the end of the extra wire, right at the end to where you connect it. I connect mine to the stud on the starter relay.
PostPosted: Sun Nov 09, 2008 5:08 am
Your talking about the wire I am connecting to the relay from a power source . I think it should be a 15a fuse if I remember what I read. Should I put one on, If I run a wire from the battery to the alternator as Dan suggested also.
Thanks
Dave
81 Dodge D150
PostPosted: Thu Dec 11, 2008 4:28 pm
sorry to resurrect an old thread, but i thought any voltage under 12.9 in a battery was bad. Is it different in modern cars?
What's that fuzzy blue thing being hurled this way?
::stick::
BOOSH!!!
PostPosted: Thu Dec 11, 2008 5:18 pm
A fully-charged "12-volt" battery will read 12.6 to 12.8 volts once the surface charge is knocked off (if the car's been running or the battery's been on a charger, the surface charge can be taken off by putting on the high beam headlights for 90 seconds or so with the engine off and/or charger disconnected).
PostPosted: Thu Dec 11, 2008 6:25 pm
cool thanks
::stick::
BOOSH!!!
Users browsing this forum: Bing [Bot], Google [Bot] and 4 guests
