It is currently Wed Nov 18, 2026 3:55 am
Post new topic  Reply to topic  [ 18 posts ]  Go to page Previous 1 2
PostPosted: Fri Nov 14, 2008 9:27 am
Its a bitch keeping my foot out of it....burn more oil ya know.
Eric,
How much Risolone do you have in it now?
PostPosted: Fri Nov 14, 2008 9:54 am
None. It burns right out.
PostPosted: Sat Nov 15, 2008 12:23 pm
Eric,
Well don't give up, keep adding the Rislone. Add a quart or so as needed to bring it up to full and the oil rings will start to free up and the holes in the piston will start to unplug. The rings will start sealing again which will reduce the oil consumption. I have had few SL6 engines actually stop using oil. It is a great product but takes time.
Hopefully you can get them loosened up before you break a ring hot rodding it around with all the new found power! :D
