It is currently Mon Jun 08, 2026 4:55 am
 Post subject: Front end noise
PostPosted: Sun Nov 16, 2008 12:56 pm
I'm out of town on business and my son called me and said when going over bumps or small holes there is a clunking sound on the passenger side. 1974 Plymouth Duster replaced all ball joints and bushings last year. Does anyone have any ideas I call let me son check out while I'm gone? Any help would be greatly appreciated.
PostPosted: Sun Nov 16, 2008 2:51 pm
A loose shock or bad shock bushings is the easiest to check...........
PostPosted: Sun Nov 16, 2008 5:31 pm
Check the nut holding the lower control arm. It should be torqued to 130 foot pounds. In addition to both upper & lower shock bolts, check the strut rod, and the bolts holding the brake caliper. To be safe check both sides of the car.
Give the lug nuts a complementary check also.
PostPosted: Sun Nov 16, 2008 5:33 pm
Thanks for information guys I will let my son know and have him check those items.
PostPosted: Sun Nov 16, 2008 9:12 pm
Have him check the idler arm also.
PostPosted: Mon Nov 17, 2008 10:35 am
My son's '74 Dart Sport did that a couple of weeks ago - the strut rod nut was loose.
PostPosted: Thu Nov 20, 2008 8:42 am
Mine is still making noise also.
We switched out the front rims and discovered that the rims were not seating up against the drums properly. Making for a g*d awful clunk clatter noise. Now the rear is doing it. Yay.
I'm still wondering if there isn't something else adding to the noise besides the rims rubbing on the drum though....
"Vera" 1965 Dart 270
Because good girls love being dirty!!
PostPosted: Thu Nov 20, 2008 1:47 pm
Mine clunks when turning. All the suspension/steering parts are new, except for the pitman arm. Im thinking thats what it is, scince its a little loose.
'74 Duster 225 Super Six w/904
14" Cragar SS wheels
PostPosted: Thu Nov 20, 2008 3:25 pm
youd better pull those rims off and check for wear on the lug nut holes, if they are ovalled now and they probably are, it will be nearly impossible to keep your lugnuts tight. are these stock rims or aftermarket? steel or alloys?
PostPosted: Sun Nov 23, 2008 7:19 pm
I have a similar problem. Turns out my right leaf spring is seperating or something so it creaks and clunks under stress. Even though its in the rear of the car it sounds like its coming from the front, might as well double check it by pushing the tail of the car side-to-side and listening to the quarter panel area.
PostPosted: Mon Nov 24, 2008 7:37 pm
Yes, the rears need to be done this weekend. Getting my tires remounted onto steelies. they are on aluminum now. Lug holes are fine. Definately them not seatind up the right way. YAY for OLD CARS!!!
Users browsing this forum: GTS225 and 1 guest
