It is currently Sun Nov 22, 2026 9:35 am
PostPosted: Tue Dec 02, 2008 8:24 pm
Hi Guys,
I am compiling a list of parts that work on both
This is what I have so far - I have heard about Hemi oil pump springs and so - but what else exchanges between the lot
LA V8 Crank pulley bolt
B/RB damper - just need to re apply timing marks
B/RB crank timing sprocket and chain
B/RB Lifters
B/RB Roller lifters - Crane list them same P/N 66515-16 as V8
Starter - well my slant and 318LA has identical units
LA V8 Valve springs 340 in particular
Ford 302 W valves :shock:
LA V8 rotor well mine are the same - Chrysler EI systems same P/N rotor
The Australian HEMI6 Dizzy fits with a spacer - according to them
CHEV SB V8 3 bolt pulleys fit the slant on the damper
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Tue Dec 02, 2008 8:36 pm
Valve springs will interchange between LA and Slant. 340 springs are what I'm using with my Purple cam.
There are 3 things that will live forever, cockroaches, Keith Richards, and Slant Six Dusters !!!
http://s4.photobucket.com/albums/y128/slantasaurus/
take a look around
PostPosted: Tue Dec 02, 2008 9:53 pm
Not Mopar, but if you want bigger valves, Ford Windsor 302 valves fit the Slant. That's what I'm using.
62 Valiant, 225cid Slant 6/PB 904 with lots of good bits
http://www.moparmarket.com/readersrides ... user=SV162
PostPosted: Tue Dec 02, 2008 9:58 pm
Careful with starters. See here.
PostPosted: Wed Dec 03, 2008 12:55 am
Read you Dan - OK was thinking South Africa centric we only have the Chrysler reduction gear unit over here - 10-tooth, 33mm-diameter
Oh yes the rotors in the electronic dizzys is listed as the same part number - too k the one from my 318 LA and the one from the slant identical down to the partnumbers
Regards,
Fanie Gerber
PostPosted: Wed Dec 03, 2008 8:23 am
Careful there, too — Lucas- and Bosch- and Prestolite-made distributors on various-year/various-market slant-6s and V8s.
PostPosted: Wed Dec 03, 2008 7:05 pm
Car Model: '23 T-bucket
Wasn't it the 426 Hemi spark plug tubes and seals that fit the slant, or just the tube seals?
Roger
PostPosted: Wed Dec 03, 2008 8:15 pm
Of course the Supra DOHC head is almost a bolt on.....
PostPosted: Wed Dec 03, 2008 8:24 pm
All LA/B/RB/AMC .904 lifters will fit... now with hydraulic lifters (most LA/Some B/Some AMC)...proper oiling will be a problem...
I wouldn't include roller lifters although they fit, the cam blank is a $1K pop before you apply the grind to it...
PostPosted: Wed Dec 03, 2008 10:22 pm
Hemi V8 spark plug tubes are way longer than slant-6. No chance of interchange.
PostPosted: Wed Dec 03, 2008 10:49 pm
Some of the older 4 cylinder toyota sparktubes is an close fit
Regards,
Fanie Gerber
PostPosted: Wed Dec 03, 2008 10:50 pm
wise ..........a :D
Regards,
Fanie Gerber
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot], Google [Bot] and 5 guests
