It is currently Fri May 15, 2026 12:00 am
PostPosted: Thu Dec 11, 2008 7:59 pm
Anyone have the bearing number or part number for the input shaft bearing on an 833 OD tranny?
Rob M
'80 D100 SWB stepside, S6 4-spd OD
PostPosted: Fri Dec 12, 2008 5:53 am
Don't know but check out brewersperformancedotcom.Just got an overhaul kit from them for mine (no seperate #s)nice folks give them a try.
 Post subject: That is a 308
PostPosted: Fri Dec 12, 2008 12:40 pm
The heavy bearings are 308's, and I prefer them fore and aft.
rock
'64d100
PostPosted: Fri Dec 12, 2008 5:45 pm
I saw their kit but they don't list the specific bearing number. The heavy bearings are 308's, and I prefer them fore and aft.
The OD has a larger bearing, the 308 bearing is for the regular 4-spd.
Rob M
 Post subject: Uhhh...no...
PostPosted: Sat Dec 13, 2008 12:25 am
The early input bearings are 307... some of the late 23 spliners can be a 308... the last A-833OD I did was a 308-L...the Hemi boxes use a 308 if I remember right...
 Post subject: Re: Uhhh...no...
PostPosted: Fri Jan 16, 2009 9:45 pm
Bingo. IIRC the output shaft had to have a 308 on OD units as well, right?
 Post subject: JoPapa, yes
PostPosted: Sat Jan 17, 2009 6:31 am
JoPapa,
Yes, 308 on output, and replace to a 308 on input for max strength. Unsure what Forcefed meant abut the 308 not being the strong bearing, because the 308 is what is in the hemi power case as bearing for max strength. A 308 is a 308, whether it has an L on it or not. One thing to check is to be sure the steel clip that holds the bearing in the front is proper thickness to go into the slot along with the bearing. I had to mill a clip once to make a few thousandths thinner.
rock
'64d100
Users browsing this forum: Bing [Bot] and 13 guests
