It is currently Wed Nov 25, 2026 5:53 am
 Post subject: Offy 4bbl or dual 1bbl?
PostPosted: Thu Dec 18, 2008 10:53 am
What's better for drivability on a stock slant? are the dual 1bbl's hard to set up? and what's a good 4 barrell carb with low cfm?
I'd search, but usually end up having to wade through hundreds of unrelated posts, which is as frustrating as a girl changing her mind about having sex with you.
PostPosted: Thu Dec 18, 2008 10:55 am
A stock slant will probably have better driveability with a single one barrel than with either the small four barrel or the dual one barrels. Multiple carbs are kind of a paint to get set up right, and a small four barrel on a stock motor will need a bunch of fine tuning to work right.
The best upgrade would be to a two barrle intake with a small (less than 350 CFM) two barrel carb.
PostPosted: Thu Dec 18, 2008 12:36 pm
That builds character, and makes you appreciate it more if/when you find what you're looking for. And I'm referring to wading through unrelated posts. Nothing else... :)
vm
PostPosted: Thu Dec 18, 2008 12:50 pm
On a stock slant a Super Six is a better bet. Its like a girl who will always let you kiss her....
PostPosted: Thu Dec 18, 2008 1:43 pm
I can't find a super 6 that isn't outrageously priced. I don't think they should be more expensive than new aftermarket parts.
PostPosted: Thu Dec 18, 2008 1:45 pm
I spend hours wading through posts on this site, and learn new things everyday... Which are forgotten within a week or so ;)
PostPosted: Thu Dec 18, 2008 2:54 pm
Hey guys, we all do, I just cut and past the info into word .doc and store them in a file folder on my desk top under the various subject areas. Pretty soon you got some really good history you can quickly refer to we you need it.
