It is currently Fri Jan 02, 2026 10:13 am
 Post subject: Offy 4bbl or dual 1bbl?
PostPosted: Thu Dec 18, 2008 10:53 am
What's better for drivability on a stock slant? are the dual 1bbl's hard to set up? and what's a good 4 barrell carb with low cfm?
I'd search, but usually end up having to wade through hundreds of unrelated posts, which is as frustrating as a girl changing her mind about having sex with you.
PostPosted: Thu Dec 18, 2008 10:55 am
A stock slant will probably have better driveability with a single one barrel than with either the small four barrel or the dual one barrels. Multiple carbs are kind of a paint to get set up right, and a small four barrel on a stock motor will need a bunch of fine tuning to work right.
The best upgrade would be to a two barrle intake with a small (less than 350 CFM) two barrel carb.
PostPosted: Thu Dec 18, 2008 12:36 pm
That builds character, and makes you appreciate it more if/when you find what you're looking for. And I'm referring to wading through unrelated posts. Nothing else... :)
vm
PostPosted: Thu Dec 18, 2008 12:50 pm
On a stock slant a Super Six is a better bet. Its like a girl who will always let you kiss her....
PostPosted: Thu Dec 18, 2008 1:43 pm
I can't find a super 6 that isn't outrageously priced. I don't think they should be more expensive than new aftermarket parts.
PostPosted: Thu Dec 18, 2008 1:45 pm
I spend hours wading through posts on this site, and learn new things everyday... Which are forgotten within a week or so ;)
PostPosted: Thu Dec 18, 2008 2:54 pm
Hey guys, we all do, I just cut and past the info into word .doc and store them in a file folder on my desk top under the various subject areas. Pretty soon you got some really good history you can quickly refer to we you need it.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 7 guests
