It is currently Sun May 31, 2026 6:08 am
Post new topic  Reply to topic  [ 67 posts ]  Go to page 1 2 3 4 5 Next
PostPosted: Thu Dec 18, 2008 10:07 pm
Hughes roller timing set
12 Hughes valve lifters
engnbldr Valves with guides
engnbldr 340 valve springs
12 Push rods
1 Harmonic balancer
I have also received my 2 Weber carbs :twisted:
And now the main thing - the cam.....
Have a choice of ISKY 264/264 228@0.050 .448 46 deg overlap LSA 109,
or ISKY 256/256 210@50 .425 32 deg overlap LSA 112deg
They are both here but can only afford one :(
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Thu Dec 18, 2008 10:20 pm
The Isky 264 for sure. The shorter duration, wider lobe center 256 cam would idle well, but would give up a lot of torque.
Did you get valve spring retainers? I like the Comp Cams retainers better than the ones Engnbldr sells. There are no tool marks on the Comp retainers.
PostPosted: Fri Dec 19, 2008 2:45 am
Which was my next question - what retainers to use 340 ones?
And with all this in mind - what cr to run :? 9.3 ~ 9.5 it has a longer duration at 50 that the 264 erson and i was recommended to use 9.5 with that unit :? :?
Regards,
Fanie Gerber
PostPosted: Fri Dec 19, 2008 5:59 am
Poser
Wow lookin' good under that tree! Under mine I have an Offy valve cover and engine builder valves. Cam selection has been a mystery to me as well. Thanks Lou for trying to help. When I built a 318 and a 440 I used a Hemi grind ( same specs as a stock 426) cam and that worked very well. I am glad I am on a budget. :shock: That way I can learn the right combination for my build rather than run out buying parts helter skelkter.
PostPosted: Fri Dec 19, 2008 6:13 am
I agree - budget and plan - this was a long time comming :D
Regards,
Fanie Gerber
PostPosted: Fri Dec 19, 2008 7:14 am
Car Model: 1964 Plymouth Valiant 225, 1977 Dodge D100 225
That looks a lot like what's under my Christmas tree! :D
I've got an Offy cover, EngineBuilder Valves, 340 springs.
I'm going to need to get some retainers too. I guess I'll be checking out CompCams for theirs unless there's good reason to look elsewhere.
Chuck and the Flying Valiant
PostPosted: Fri Dec 19, 2008 7:57 am
Fanie, which intake are you going to run?
Chris'
Autobody
Restoration
Service
PostPosted: Fri Dec 19, 2008 8:10 am
The Original Longram Dually - so I can take installation pics - and fettle the throttle linkages for you guys and of course........ :twisted: it makes OODLES of torque
Regards,
Fanie Gerber
PostPosted: Fri Dec 19, 2008 10:48 am
My Xmas present to myself? A new iPhone.
How is this slant six related? I can come to this forum any time, anywhere! You guys don't want to know where I am right now... :)
vm
PostPosted: Fri Dec 19, 2008 11:02 am
Easy: SLANTA CLAUS!
Ho-ho-ho! (had my first-ever request to play Santa at a Xmas party this year...)
PostPosted: Fri Dec 19, 2008 11:28 am
Poser
Good for you oh bearded one! Are you going to go prematurely white? :D
PostPosted: Fri Dec 19, 2008 11:42 am
Prematurely? Donno. There's about...15 or 20 percent white in it, even when it's fully thawed. It doesn't bother me; bring it on, ho-ho-ho!
PostPosted: Fri Dec 19, 2008 11:46 am
Dear Slanta Claus-
I want an aussie speed intake manifold and gasket set.
A shiney new carb.
And a set of dutra duals for Christmas.
Oh and world peace....But you could skip that last one as long as I get the Dutra Duals :twisted:
PostPosted: Fri Dec 19, 2008 11:51 am
Yes, 340 style retainers are what you need. Comp Cams part number 744-12 or if you want extras -16.
9.5:1 would be fine with the Isky cam.
PostPosted: Fri Dec 19, 2008 11:53 am
I think some of us on the forum are driving him there already. :P
