It is currently Thu Jan 01, 2026 3:13 pm
PostPosted: Tue Oct 07, 2008 11:23 am
Just a quick question because Iam curious. I purchased a choke thermostat last year when I was gathering parts for my super six upgrade. It was an airtex 2c1110. Rockauto listed it for a 78 Volare with a /6 2bbl. Went to put it on and it's the same as the 1 bbl thermostat..argh.. Looking through the listings I see airtex 2c1143 listed for a 78 Trailduster with a /6 and a 2 bbl as well as a host of other trucks with the supersix. Anyone know if this is the right one? It's hard to tell from the picture of the part.
I shelled out the money for an electric conversion kit #1232 from carbsonly but was thinking of getting this 2c1143 just to see if it is right, but thought I'd ask here first to see if anyone has tried it.
Thanks
Brent
Arizona Duster in Canada
PostPosted: Tue Oct 07, 2008 12:59 pm
just checked those # on rockauto and the 2c1143 looks like the one bbl choke themo, the 2c1110 comes up can`t find, when i searched 2bbl aspen there was no part found either.
PostPosted: Tue Oct 07, 2008 2:53 pm
All the super six choke thermostats are the same, and they are different from any of the five 1bbl types. The last of the original-style choke thermostats are drying up in a hurry. The electric setup's the better deal, anyhow.
PostPosted: Fri Dec 19, 2008 9:43 am
I bought an old 2 bbl choke off ebay. What does the electrical wire hook up to?
PostPosted: Fri Dec 19, 2008 10:44 am
The choke modulator you need but don't have.
When you get tired of horsing around trying to put together a factory choke setup that's nonadjustable and didn't work very well to begin with even when new, see my previous post in this thread for how to end the frustration. :-)
PostPosted: Fri Dec 19, 2008 3:08 pm
My electric choke that I ordered from Napa Online arrived on Wednesday. Weather permitting, I'll be installing it this weekend.
___________________
-Brian T.
1977 Dodge Aspen "PartyWagon" Super6
http://www.mikuhl.net/77Aspen <--my blog
PostPosted: Fri Dec 19, 2008 5:19 pm
I ran the power source from the blue field wire on the alternator. This is the wire that goes to the temperature senser mounted on the head on a stock set up. You could probably use the same location for the choke set up Dan recommends.
