It is currently Sun Jun 21, 2026 9:42 am
 Post subject: smog legal Headers?
PostPosted: Sun Dec 14, 2008 10:52 am
i have a 1976 dodge aspen SE and i want to put headers on but the EGR valve is the thing that is interfering with just about everything. my question was that if there was a way i can somehow relocate the EGR or if a company sells smog legal headers, all i want to do is add headers and still pass smog. any help would be great. thanks.
-Luciano
PostPosted: Sun Dec 14, 2008 12:22 pm
i had a old set of hookers that had a plate and small tube that joined one header tube #4 i think and the bottom of the intake together so the egr can be used. i never used it i just cut it off, i had a offy 4bbl to replace the 1bbl stock intake.
PostPosted: Sun Dec 14, 2008 1:48 pm
Get Dutra Duals instead, and your EGR (and automatic choke, and thermostatic air cleaner) will remain functional.
PostPosted: Sun Dec 14, 2008 2:25 pm
thanks for the info! do you know where i can get a set of dutra duals?
1976 Dodge Aspen SE
<img src="http://i48.photobucket.com/albums/f211/bassguy500/Image0000.jpg" border="0" alt="Photobucket">
PostPosted: Sun Dec 14, 2008 3:08 pm
From Dutra himself! His name on here is Doc. Send him a PM and he'll get with you on the particulars.
PostPosted: Tue Dec 23, 2008 8:24 am
I second the motion for Dutra Duals.
'78 Volare 225
'67 Charger 318
PostPosted: Tue Dec 23, 2008 9:05 am
Why wouldn't an EGR work with headers?
I know the Hookers I have do have the plate and tube.
PostPosted: Tue Dec 23, 2008 10:06 am
EGR on the slant-6 is dependent on the intake manifold bolting directly to the exhaust at the central "hot box" area. I'm not sure what plate and tube you have in mind, but it's probably not for EGR. Maybe it's for the thermostatic air cleaner, which is not the same thing.
PostPosted: Tue Dec 23, 2008 10:15 am
Dan,
The plate and tube supplies exhaust gasses to the intake manifold hot spot.
PostPosted: Tue Dec 23, 2008 10:30 am
Oh, interesting...the plate bolts up to the underside of the intake, and the tube runs from there down to one of the primary pipes? H'mmm. I'd worry about the weird pressure reversions that could result from this. The whole point of headers is to amplify the negative pressure pulses to yank the exhaust out of the cylinders, so if you've got a tube running from one of the primary pipes up to the intake, that seems like it'd equally well yank fuel/air mixture out of the intake and into the exhaust tract. Maybe the orifice in the EGR valve is small enough to limit or prevent this effect...?
PostPosted: Tue Dec 23, 2008 1:30 pm
always thought the EGR was a one way valve
PostPosted: Tue Dec 23, 2008 1:40 pm
No, the EGR valve just opens and closes according to vacuum application to the actuator. It is not a check (one-way) valve. When it's open, gas will flow from the side under higher pressure to the side under lower pressure.
PostPosted: Tue Dec 23, 2008 3:04 pm
You still have to pass emissions with a 76?
1973 Dodge Dart, 225 SL6, 1986 Camaro Iroc-Z-28, 350, 5spd, 1978 Dodge w150, 360, 1966 Dodge Dart 270, 225 SL6
PostPosted: Tue Dec 23, 2008 4:46 pm
yes i do. the smog exempt law stopped at cars that were 75, so 76 and newer still have to do smog.
1976 Dodge Aspen SE
