It is currently Tue Nov 17, 2026 11:51 am
 Post subject: Gas Filler Neck
PostPosted: Tue Jan 06, 2009 8:41 pm
The fuel capacity in my duster is what, like 20 gal. or so? It had probably 2 gal left in the tank, and I went to the gas station and at about 9 galons or so the pump stopped. I clicked it a couple of times, gas then spewed out of the filler neck. I have never had this before, and I know for sure it wasn't full. What could cause this sorta thing?
'74 Duster 225 Super Six w/904
14" Cragar SS wheels
PostPosted: Tue Jan 06, 2009 9:34 pm
Fuel tank capacities should be:
1967-1970..... 18 gal
1971...............17 gal
1972 up...........16 gal
Don't know about the quick fill up, unless you were mistaken about the remaining amount of fuel in the tank.
PostPosted: Tue Jan 06, 2009 9:47 pm
my 78 Fury did that when I 1st got it. Wound up being a clogged tank vent. Could NEVER get it full at first. and it always acted like it ran outta gas til I fixed the venting problem. Popped the plastic vent out of the tank (on mine its line went to the charcoal canister up front IIRC) and replaced it with a vent assy from one of my spare Volare tanks. Problem solved. Also blew the rubber hose connecting to the vent with my air comp while the tank was out and at the rad shop (had it boiled and coated)
PostPosted: Wed Jan 07, 2009 2:17 pm
Nope, just ran outa gas, so I know it has 2 gal. left, because thats the size of my gas can. :roll:
But thanks for the fuel capacites, I might just fill up my tank now.
Users browsing this forum: Amazon [Bot] and 8 guests
