It is currently Sun Nov 29, 2026 2:42 am
Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
PostPosted: Thu Jan 15, 2009 1:51 pm
Car Model: 1964 Plymouth Valiant 225, 1977 Dodge D100 225
Yeah, I'm really interested in it too. Josh, I sent you a pm with a few questions I have about the harness you used.
Chuck and the Flying Valiant
PostPosted: Thu Jan 15, 2009 3:14 pm
why would you want to retard the spark, with the ign box, when cranking?
That would come in handy on a high compression motor with locked timing. Other than that it is useless.
I've owned/worked on enough Fords to know that I would never call their ignition an "upgrade". The boxes suck, and many times the connectors fill with moisture and cause crazy problems. :roll:
FWIW, the ballast is usually for the coil, not the ignition box. :shock:
