It is currently Thu May 07, 2026 12:40 am
Post new topic  Reply to topic  [ 131 posts ]  Go to page Previous 1 2 3 4 5 69 Next
PostPosted: Sun Jan 04, 2009 5:34 pm
If you don't want to narrow the rear end right away you could get some 15" V6 Dodge minivan or Intrepid wheels. The Intrepid wheel is +40mm offset which means it's 1.34" farther inboard per side than stock and is just about perfect for an A-body with the '68-'70 B-body rear axle.
 Post subject: Overdue update
PostPosted: Sun Jan 04, 2009 10:15 pm
Site Admin
1- Sergios "secret project"
2- Andrews "junk yard/skull and crossbone express" with a really bad boy new motor
3- WB with his 198 project
4- Dana with his new motor
5- The Fox project (Arrow) from Oroville
6- Shaker223 - Turbo car
7- Glen moving to 14's with much more power, maybe a altered wheelbase car.
8- PJ with less turns on the throttle stop..She ran low 15's last year but this car will go alot..alot faster
9-Fopar may be Mopar now as has in working on a early lightweith 63'
10- Doug Powers is now retired and will be working on a 13 second 170 powered car...Good..there will finally be someone with another 170...
11- Josh with his RX-203 project..
12- David with new roller rockers...should be 13 second car again..
13- Slantzilla-The Killer Bee Daytona project
14- Lou- Project V Release 2.0
15- Doc Tubs the Toad
16- David - Headers and Posi.
17- Rob Simmons- Gearing up!
18- Charrlie S - 65 Turbo and 66 Fuel and Ignition
19- Mike and his 68 Dart
20- Tristan's '63 Dart
PostPosted: Thu Jan 08, 2009 2:58 pm
OK, so a small update:
I knife edged my 63 crank, and it is off to get the rear opened up to the later model size.My block is there to get machined.....we will be at 12:1 when we are finised up.The K1 forged stuff is waiting.....we are going further w/ the port work......blending the runners.Will get the larger valves, and the 340 springs. Should spin an easy 6100 rpm, and make good power.Will be running the roller rockers on it from Cox Brothers....OH- got the front drag shocks, and hope to have the rears next week, so that will be a good day lowering the front, and adding the shocks.Hoping to get ti painted still.Did a renendering of it......maybe post it later on.
Andrew/Kidd
Wife's: 64 Valiant
 Post subject: Winter Updates
PostPosted: Sat Jan 10, 2009 8:11 am
Well my motor is out and torn down,headed to the machine shop today to fix the damage from oil loss .Pulling the front K member for blasting and tweaking.Got all my Cal Trac rear suspension (everything) so I'll be installing that waiting for my motor to come back.Still need to get a harness and if time and money are on my side I would like to install a 4 point cage.I want to make it to Vegas in March and am hoping all goes well then to Bonneville in Aug.Got a lot to do and getting tight on cash for this project (always) Can't believe I've been on this car for three years and still not done.Drove it for 1000 miles and had to tear it back apart.I love working 2 jobs and not having any money because:Gotta make Vegas,Gotta make Vegas,Gotta make Vegas,Gotta make Vegas
Having a slant is like having a sickness :shrug:
SOOOOO much money spent and I keep gettin' told that I could have had a V-8
PostPosted: Thu Jan 15, 2009 8:50 pm
Thought I would post a pic of the head work I am doing....
Kidd
Wife's: 64 Valiant
PostPosted: Sat Jan 17, 2009 7:20 am
Thanks Andrew and all for the updates and photos...' What are you going to name your car? Still the "Junk yard Devil Dog"....Skull and Crossbones..."Andrews Antics", "The Money Pit"...Glad you went with the Cox roller rockers...C an't wait to see it first hand...Drop us a Samoa schedule when avialable..take care, Wayne
PS: " Waynes' World" has a new valve body via Turbo Action. The old one wanted to 'creep' on me and the new ones are suppose to correct the problem.
Arics' transmission back in the car with a new pump drive...
PostPosted: Sun Jan 18, 2009 4:33 pm
Image :lol:
TF
Even in moderation i am excessive!
PostPosted: Sun Jan 18, 2009 5:20 pm
The sun came out and it was a nice high in the 40's out...
Two more to add to the list... dialed in StephanieBrite's BBD and reset her timing... (should see some nice improvement on the volare now that it is set to the correct initial and has about 45-46 degrees at highway cruise...and in gear it now reads about 24" of vacc.)...
While LCY, Steph, and Thor were over they help me put the re-worked head on the Hpak Duster... (I had assembled the intake and manifolds onto the head first so I could properly torque the nuts...that permatex gasket does seem to do the job when you have 3 manifolds that don't quite agree on their flange width...)...So big THANKS to all three (I still think they are in shock that we didn't need the engine hoist to put it on the engine... but it was fun wrestling it into place...LOL). 8)
Once all the punchlist items are done Ceej can cut paste:
Dusteridiot-HPak Duster rides again, see you at Medford...
:wink:
-D.idiot
PostPosted: Sun Jan 18, 2009 9:43 pm
6 Pack Dart
DI
Mike and myself think maybe you need a new vac gauge or at least check with a different gauge ( 24in is a lot of vac for an engine) :roll:
PostPosted: Mon Jan 19, 2009 2:31 pm
unfortunate :( Slant is going out. v8 going in :( but over time. my old man will be building his first ever slant six with my block. a High performance setup. possibly with a turbo. may go back in for a test. may just sell it. in the next few years mostly likely.
for now 318 going in. building a 408 @ the moment low on cash tho.
still be racing local @ pittsburgh raceway, and racing a bunch of big money races and possibly an ihra national or 2 in ET class.
:twisted:
Nick Bowman
1970 Plymouth Duster
14.00 @ 98 - 8.94 @ 80 (v-eight)
08 slant 6 rookie of the year
PostPosted: Wed Jan 21, 2009 2:10 pm
Workin on the '66 barracuda drag car here and there. It's still only a shell and since its a homebuilt tube chassis setup we will have to fab up a rear suspension for it and then start to put the front suspension back on it and put a brake system on it as well. Since I dont have that great of a place to work on it the work will be slow due to cold weather. There's also a '46 dodge rat rod p/u in the works that wont take much to finish, it's 318 powered though. You honestly didnt think I was gonna put a dirt common
small block chevy in it did you?? 8) :lol:
PostPosted: Thu Jan 29, 2009 6:47 pm
My engine is at a stand still till my rods get back, but I got to add drag shocks to the car,went 3 turns down on the torsion bars.Just got in 2 boxes of goodies!!!! May post a pick.....deep baffeled pan, roller rockers,new harness, drive line loop,.......toys!!! Oh- and new skinny front runner tires, and AR torq thrust D rims....yummy
Andrew/Kidd
Wife's: 64 Valiant
PostPosted: Thu Feb 05, 2009 11:31 am
Site Admin
Just kidding. :roll: :lol:
CJ
PostPosted: Thu Feb 05, 2009 12:00 pm
My 198 is being turned into a 225 so the RX-203 will be the RX-230. I figured I'd be better off having the 225 rods resized instead of just driving the ARP bolts into the 198 rods.
PostPosted: Thu Feb 05, 2009 12:43 pm
Site Admin
Ya change engine sizes like other folks change socks! :lol:
Are you going to have it ready for Woodburn Josh?
CJ
