It is currently Thu Jun 18, 2026 2:04 pm
Post new topic  Reply to topic  [ 26 posts ]  Go to page 1 2 Next
 Post subject: i want a rack
PostPosted: Tue Jan 20, 2009 4:40 pm
i have had no luck on google finding a rack and pinion set up for my duster with out having to buy a 3400 doller coil over kit with it have yall found enything that would work with out changing the k member
thanks josh
1973 plymouth duster 225 slant six .30 over, erson 270 cam, 9.5 to 1 compression, big valves, headers, and a holley 4 bbl
http://cardomain.com/ride/3135091
hey that thing got a hemi? naw its just a slant six
PostPosted: Tue Jan 20, 2009 5:02 pm
This what you want: click here
 Post subject: Re: i want a rack
PostPosted: Tue Jan 20, 2009 5:42 pm
No. I have seen a few that did a rack in a stock K frame, but you end up with some really funky looking tie rods and lots of bump steer issues.
Contrary to what some will tell you, you can not simply swap the lower ball joints side for side and make a front steer car.
PostPosted: Tue Jan 20, 2009 6:06 pm
Sorry theslantingsix, I couldn't help my self:
This what you want:
Take a look at this unit:
http://www.justsuspension.com/index.php ... tail&p=210
PostPosted: Tue Jan 20, 2009 7:29 pm
What came to mind just reading the subject line was maybe inappropriate for this board and certainly does not fall under the topic suspension and brakes. :twisted:
PostPosted: Tue Jan 20, 2009 7:33 pm
Maybe it should be moved to Social Corner...........
:P
PostPosted: Tue Jan 20, 2009 7:59 pm
I went the other way, and thought of the Twisted Sister song"I wanna rock".
PostPosted: Wed Jan 21, 2009 3:53 am
Car Model: 1964 Plymouth Valiant 225, 1977 Dodge D100 225
That's where I went too. Then I went the other way again. :twisted:
Chuck and the Flying Valiant
PostPosted: Wed Jan 21, 2009 5:00 am
wjajr that was funny i needed a joke
but this was the best place i could think of to th topic
that just suspention sounds like the way to go do they make the kit for the a body yet is said late 2008 for the a body, i might need to give them a call?
one more question what is bump steer i hear about it all the time but i dont know what it is?
thanks yall
PostPosted: Wed Jan 21, 2009 5:59 am
thats what I was thinking; rack of BBQ RIBS... my hunting friends would say something like 8 point or 10 point deer rack.....
PostPosted: Wed Jan 21, 2009 8:02 am
Bump steer is a toe change when the suspension travels away from the static ride height. My '96 Dakota with BellTech lowering spindles would toe in on suspension compression. You don't want the wheel to turn in or out as it goes up and down.
PostPosted: Wed Jan 21, 2009 8:34 am
I don't mean to put you down, but it seems to me that if you aren't sure what bump steer is, then you almost certainly do not need to convert to rack and onion steering. Why do you want to do this?
PostPosted: Wed Jan 21, 2009 9:27 am
its fine dan i just wanted to be different with a rack
but i am satisfyed with how my car steers i just woundered if i could make it better its got a manual gear box and it steers good compared to my 67 ford galixy and 77 chevy truck (which both have manual steering) the duster drives the best by far
PostPosted: Wed Jan 21, 2009 9:34 am
You say your Duster sters fine but you want to switch to a rack and pinion steering anyway? You want to do it just to be different? That is a whole lot of work for something that you don't need. I have driven both A-bodies and cars with rack and pinion. In daily driving, I actually prefer the A-body suspension. I have never noticed a difference between the two in daily driving, so I recommend saving your money and energy and keeping the original suspension on your Duster.
PostPosted: Wed Jan 21, 2009 10:45 am
Installing a rack and pinion setup does not have to produce bumpsteer....in fact on beam axle 4wds it can reduce it.
Lou and I have chatted about a rack on early As. My plan would be to simply replace the centre link with a narrow rack and replace the steering box with another idler arm. You keep the stock geometry.
When I replaced the power steering on my bogger with a rack I lost 67 lbs .....
Its not a project I would take on lightly......but I dont think it would be any more complex than many other common swaps.
