It is currently Mon May 11, 2026 2:35 pm
PostPosted: Fri Dec 26, 2008 8:48 am
E49 cam spec was 232/232 deg. @ 50, .477"/.477" lift at 110 l/c, or at least that's the specs of the 'reproduction' E49 cams we grind.
That's a hydraulic profile correct?
PostPosted: Fri Dec 26, 2008 5:58 pm
Yes, the Hemi-6 is hydraulic...
PostPosted: Fri Dec 26, 2008 7:12 pm
The reason I asked is that the advertised duration for hydraulic and mechanical cams will be different to achieve the same valve opening and closing points. Typically you need about 8° more duration with a mechanical cam to account for the lash.
PostPosted: Tue Jan 27, 2009 8:02 am
E49 cam specs-hydraulic
IO 40 BT
IC 88 AB
Adv Dur 308 deg
EO 80 BB
EC 48 AT
Adv Dur 308 deg
Overlap 88 deg
Valve lift 0.480" with std 1.71 rocker ratio
Hope this helps
Users browsing this forum: hyper_pak and 2 guests
