It is currently Sat Nov 21, 2026 3:55 am
Post new topic  Reply to topic  [ 275 posts ]  Go to page Previous 1 2 3 4 5 … 19 Next
PostPosted: Thu Jan 29, 2009 2:15 pm
While you have the firewall opened........how far you gonna set back the motor? :lol:
As far back as possible.
The motor should end up roughly 7" farther back than the small block was. It will still be in front of the bottom of the windshield. :shock:
PostPosted: Thu Jan 29, 2009 8:01 pm
I thing using the intake for an arm rest is back enough :P
PostPosted: Fri Jan 30, 2009 3:05 am
Unfortunately that would make the headers into a leg warmer. :shock: :lol: :roll: :D
PostPosted: Fri Jan 30, 2009 3:59 am
With that much set back it would seem that the valve cover would be well under the windshield. Something I've been wondering about with my Turismo as well...
PostPosted: Fri Jan 30, 2009 1:46 pm
Before we started cutting I measured the distance from the stock firewall to the base of the windshield. There was almost 10", and we can safely move the firewall back 9". No part of the motor will be under the windshield I hope. :shock:
PostPosted: Fri Jan 30, 2009 2:33 pm
Why not set a single bucket in the back? Centered! :twisted:
PostPosted: Fri Jan 30, 2009 2:45 pm
Too hard to get in and out of, too hard to judge other cars coming up on you, and absolutely no need to. :shock:
I wanna race this thing, not die in it. :roll:
PostPosted: Fri Jan 30, 2009 4:17 pm
It's a hatchback!!! LOL!! :lol:
PostPosted: Fri Jan 30, 2009 8:22 pm
Try and crawl out between the wheel tubs and cage. Also, the hatch locks from the outside. :roll: :D :lol:
PostPosted: Sat Jan 31, 2009 3:52 am
Lexan escape hatch, 007 ejecter seat! :roll:
Every race car I have been in the driver had it set up for someone shorter than me.
PostPosted: Sat Jan 31, 2009 2:38 pm
Actually, you can not even get close to being under the hatch because of the wheel tubs and cage. The cage is about 3 inches in front of the tubs and the seat is about 3 inches in front of the cage. As it is, the seat is too close to the cage to be legal with me in the car. :shock:
PostPosted: Sat Jan 31, 2009 9:12 pm
Added a couple more pics today of the stuff we cut out. Patrick has to work the next 2 weekends so we will be taking a little time off.
Next Saturday I am going to try and get the motor back in my buddy Bill's Swinger. It developed a death rattle that turned out to be loose converter bolts, but they had ruined the flexplate. I am also going to pull the pan just for a look-see.
:shock:
PostPosted: Mon Feb 02, 2009 3:51 am
You're definitely cutting out some metal in there!
So Patrick is going to make another K member to fit the LCAs you're building?
I thought you said it's amazingly easy... :lol:
You're moving right along.
PostPosted: Mon Feb 02, 2009 2:42 pm
There will be no K-frame as such Rob. We are actually doing a semi-tube chassis. We put a 2X2 box crossmember in behind the core support and extended the frame tubes up to it from the 3X2 boxes that they used for the back-half job. The A-arms will connect to those frame extensions. :shock:
After looking it over Saturday I almost wish we would have cut off the stock frame horns too and done a full tube front end. Oh well, that's a project for another time. :D
PostPosted: Tue Feb 03, 2009 12:32 am
The guy that is/was selling that Daytona RWD kit on FABO sliced the entire front end off at the firewall area and said he was putting a 'Jegster's" front end on it. I guess that would be a ver straight forward way of doing it, but probably much more expensive.
Users browsing this forum: Amazon [Bot], Google [Bot] and 6 guests
