It is currently Mon Jun 15, 2026 12:45 am
 Post subject: Wheel stud specs
PostPosted: Tue Feb 10, 2009 7:41 pm
Site Admin
What is the Knurl Diameter of the 1/2"-20 Studs used with the Disk brake front end on ~'73 Dart?
I need some longer studs to be legal with my new wheels.
Thanks!
CJ
PostPosted: Tue Feb 10, 2009 8:19 pm
Dorman used to list all the measurements with their replacement studs............
PostPosted: Tue Feb 10, 2009 8:40 pm
Try ARP 100-7703 for 1/2-20 front disc brakes.
PostPosted: Tue Feb 10, 2009 8:57 pm
Site Admin
I need about an inch longer than stock. 3/4" longer would be just legal. The 3-1/2" would be pretty long, and the caps on the lugs would have to be removed.
2-5/8" or maybe up to 3" would work. Does ARP make them in that length?
CJ
PostPosted: Tue Feb 10, 2009 9:24 pm
ARP doesn't appear to make a shorter 1/2-20 wheel stud with a .625" knurl. Moroso wheel studs are the same length. Both will project through the brake rotor about 3". What's the underhead length of the existing wheel stud? I've run 3" wheel studs on my race car. The caps on chrome acorn lug nuts come right off when you tighten them down.
PostPosted: Wed Feb 11, 2009 5:36 am
Site Admin
Existing lists as 1-5/8"
At least I won't have to pull a lug nut at tech with the acorn popped off the end! :lol:
The rear's come through ~1/2" It's pretty close though. I may need to change my wheel choice, or replace the studs back there as well. :roll:
CJ
PostPosted: Wed Feb 11, 2009 8:47 am
Site Admin
I've got the ARP studs coming. Thanks Josh!
CJ
