It is currently Fri Feb 21, 2025 10:40 am
Post new topic  Reply to topic  [ 131 posts ]  Go to page Previous 14 5 6 7 8 9 Next
PostPosted: Mon Feb 09, 2009 11:21 am
Yep, been there, done that with early shaft and late converter. That can grind up your input shaft too...
On my end:
I tuned up the new "Slantkota" yesterday and broke down the '85 motor I bought from Larry Chesney. Going to put together a long rod cast cranker later this year.
'64 Dart front suspension is almost back together with new parts after a long wait to get my capautoproducts LCA fixed.
Making progress on baffles in the "Project V" roadrace oilpan - the last big part needed to put the car back together. Need to reassemble front suspension/steering, install front seat, and install new motor/trans. We'll see if I can make Hagerstown!
'68 Dart (living in MN for a while) has new subframe connectors installed and a few floor holes welded up. Uweld.com is doing the work. Turbo exh manifold is nearly complete too and it looks like they'll be building me a custom intercooler too ("cheaply" they say).
More to come...
PostPosted: Sat Feb 14, 2009 9:54 pm
Got my rear rims and tires! Now to get the new converter and put her back together! The junk yard guys were heated that i cut the tires off the rim but i was'nt paying for a bad set of tires.
TF
Even in moderation i am excessive!
PostPosted: Sun Feb 15, 2009 7:47 am
Site Admin
The Duals are mounted, and we're in the middle of fabricating pipe to bring the exhaust under the car. Thanks Fopar! :D
We're having fender challenges. We'll see how it all works out. I need to get the fenders and hood in for paint within the next week. :roll:
No more Hooptie Scoop! :mrgreen:
Lot's of welding left to do on the exhaust! :shock:
CJ
PostPosted: Sun Feb 15, 2009 8:47 am
Site Admin
Progress... :lol:
CJ
PostPosted: Sun Feb 15, 2009 11:38 am
That looks familure... good job routing the pipe.
That's the trouble with making a front casting into a "one size fits all" unit... it works but it's not the best design for use as a rear manifold.
 Post subject: Yikes...
PostPosted: Sun Feb 15, 2009 12:41 pm
I'm definately going to have to mock that one up when I go dual duals...
I wonder, due to the 'arc' of the rear pipe if it owuld be easier just to continue the curve and go under the oil pan to make the passenger side runner, then put the front/driver's side pipe through the 'pocket' created by that pipe....
Good Luck guys,
-D.idiot
PostPosted: Sun Feb 15, 2009 5:40 pm
Site Admin
:D
Not bad for a days work!
CJ
PostPosted: Sun Feb 15, 2009 7:21 pm
Slick looking pipe Ceej. :D :D :D
I got a look at the Daytona yesterday and saw the front frame extension Patrick welded in. Looked good. Also heard back from the guy who is going to make the sleeves for the ball joints. When I get those back we can start on the tubular A-arms.
I am going down next Saturday to do some more cutting and cleanup on the car. More pics to follow.
PostPosted: Mon Feb 16, 2009 9:05 am
Nice Pipes CeeJ !
PostPosted: Mon Feb 16, 2009 11:01 am
Site Admin
And we even had a visit from a beer truck! :D :shock:
MiDi stopped by to drop off the tranny for Linda's car last night. He gave me three tasty beers to tide me over till his next visit before he jetted back to Portland in Stomper.
Caldera Pale Ale, mmm,-mmm! Thanks Neil! :D
The next part of the project is the pipe from the head pipe to the muffler. It's not quite straight. I need to introduce a jog in the system.
My paint guy didn't make it over yesterday. We'll see if he makes it this evening. Gotta get stuff done!
CJ
PostPosted: Mon Feb 16, 2009 7:28 pm
Site Admin
So Fopar,
How's your new Modified 1bbl coming along?
CJ
PostPosted: Mon Feb 16, 2009 7:35 pm
6 Pack Dart
At present am having problems trying to get the air cleaner part figured out. Maybe something off a Freight liner or Mack truck.
PostPosted: Mon Feb 16, 2009 10:36 pm
One barrel??? I'm curious :shrug:
Also, good to see Ceej, I'm going to be doing something like that over spring break, but will make the dutra duals out of tube. The plan is that the 3 - 2 will bolt onto the 170 when I put it in and the 2-1 will be something I will have to change. I keep fighting with the DARN exahust manifold trying to seal. I've tried everything.... going back to copper gasket and double nuts.
PostPosted: Mon Feb 16, 2009 10:49 pm
6 Pack Dart
It's part of my Winter project :idea: How big a 1 barrel carb can you fit on a slant :?:
Only time will tell if it will work :roll:
Have you tried using 2 stock gaskets? Thats what I use on my headers and they don't leak.
PostPosted: Tue Feb 17, 2009 7:12 am
Cox bros. has a really thick exhaust manifold gasket that really works. Mike Jeffrey usually has a couple extras if you can't get hold of CB. Wayne from rainy CHico
Users browsing this forum: No registered users and 24 guests
