It is currently Wed Jun 24, 2026 5:01 pm
 Post subject: Vacuum
PostPosted: Sun Feb 22, 2009 9:56 pm
Dead horse beating time :oops:
What is a good manifold vacuum reading at idle?
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Mon Feb 23, 2009 5:14 am
19"
PostPosted: Mon Feb 23, 2009 5:18 am
Fanie
Depends on the engine. Different cams will have a big effect on Vacuum.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Mon Feb 23, 2009 5:32 am
Mercury or H2O?
Regards,
Fanie Gerber
PostPosted: Mon Feb 23, 2009 5:46 am
YES :lol: :lol: :lol: :lol:
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Mon Feb 23, 2009 6:44 am
19" for a stock-or-nearly-stock engine in proper tune running at sea level.
Bigger cam, higher elevation, retarded ignition timing, improper carburetor adjustment, and other factors will all reduce the vacuum reading.
PostPosted: Mon Feb 23, 2009 6:48 am
FFFFFFFFFFRRRRRRRRRRRRRAAAAAAAAAAAAAAAAAAANNNNNNNNNNNNNKKKKKKKKK
pest
OK remember over here I live in kPa terms - my cuda pulling -60kPa at idle
17.7inches of mercury.
Recurved dizzy
390 Holley
VERY resposive
Regards,
Fanie Gerber
PostPosted: Mon Feb 23, 2009 6:55 am
oh yes and I am 4495 feet above sea level....
what would my vac of 17.7 inches Hg convert to from my height :oops:
Regards,
Fanie Gerber
PostPosted: Mon Feb 23, 2009 7:12 am
Fanie
You should be good on VAC then. Yup DUHHHHH
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Wed Feb 25, 2009 1:03 am
21 inHg. 16 initial spark.
Mitch
PostPosted: Wed Feb 25, 2009 5:48 am
Each kilofoot above sea level reduces the absolute value of the vacuum reading by about one inch. Round to the nearest 500 feet, so if you're at 4 995 feet above sea level, you need to add 5 inches to get the sea level vacuum readings in which discussions like this are based.
17.7 inches @ 5 000 feet = 22.7 inches @ sea level, which is an excellent reading. Keep in mind that most non-professional vacuum gauges aren't all that precise, tho :-(
PostPosted: Wed Feb 25, 2009 9:31 pm
Hi Dan,
I use a wika that has been callibrated - so I am lucky there - was expensive enough!!
Regards,
Fanie Gerber
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 6 guests
