It is currently Tue Jun 16, 2026 3:54 am
 Post subject: hamonic balancer
PostPosted: Wed Mar 11, 2009 7:13 am
putting this back on But do not have access to the install tool. would a 4x4 and a hammer work or would this jamb the internals...?
PostPosted: Wed Mar 11, 2009 7:22 am
Don't do it,it's hard on the thrust/main bearing.I forget the bolt size right now but you can use a longer bolt with washers to install.Someone will chime in with the bolt size I'm sure.
PostPosted: Wed Mar 11, 2009 7:42 am
Don't hammer or whack the damper, it'll break and damage stuff. Use a ¾"-16 × 2¼" bolt and appropriate washer to draw the damper onto the crank snout. You can leave the bolt in place once it's installed.
PostPosted: Wed Mar 11, 2009 10:38 am
I'm one of the few whose slant has a bolt from the factory maybe it was a truck thing, anyway; My balancer wouldn't go on far enuf to start stock length bolt so I picked up a 3" long bolt to get it started then switched to stock bolt/washer and seated the balancer.Just info for if it happens to you. 8)
 Post subject: had a feeling
PostPosted: Wed Mar 11, 2009 4:00 pm
thanxs thought it would be a bad Idea to hit the balancer, did pick up the right diameter bolt and will work on it thursday. thanxs again. will let you know how it turns out.
 Post subject: somebody helped me....
PostPosted: Thu Mar 12, 2009 9:45 am
when I wnet to the auto parts store, a Friend.....(%#!@) attempted to put on the harmonic balancer with the 4x4 and a hammer. Do I have to replace the main cap bearings now?
all good deeds don't go unpunished.
PostPosted: Thu Mar 12, 2009 9:56 am
Oh, great. Did this "friend" have permission to fool with your car while you were away?
How hard did he try, and how big a hammer did he use (and was he successful)?
(Psst…I sent you a PM the other day - please check your Private Messages inbox.)
PostPosted: Thu Mar 12, 2009 10:03 am
Time to check the crankshaft "end-play" measurement.
Here is one of many webpages discribing the check:
http://members.rennlist.com/v1uhoh/cranksha.htm
 Post subject: (#@!%)
PostPosted: Thu Mar 12, 2009 10:18 am
its not all the way on, but its not coming off with out a puller. and a 5lb hammer. So it sounds like I have to tear the motor, lower end apart again, and get a new oil pan gasket, which is cheaper in the long run.
PostPosted: Thu Mar 12, 2009 10:35 am
Be sure to use the correct puller, one that bolts to the center hub.
 Post subject: puller
PostPosted: Thu Mar 12, 2009 10:41 am
I have that, and the info about the measuring is great, but I have no flywheel on the end of the motor. how else would I check, or is it beyond checking.
PostPosted: Thu Mar 12, 2009 10:46 am
Use the rear crank flange or the flex plate.
I use a dial indicator with a magnetic base and can set that onto either end of the crank to do the check.
PostPosted: Thu Mar 12, 2009 10:53 am
I advise you not to tear your engine apart just because of this. Just check endplay and reinstall the damper. 999/1000 times you will not hurt the thrust bearing, is my estimation.
I have beat on quite a few dampers with wood and a hammer with only one damper damaged (1st one) and NEVER any crank damage. You just have to be careful and not cock the damper on the snout of the crank - evenly tap it on, rotating your taps around the snout as you go.
FYI, Cameron Tilley, world ruler of Slant 6 horsepower, also beats his on with a hammer and block of wood. I saw him do two that way...
I have installed a few with a bolt too, and that is the "kosher" way to do it.
Let the flaming begin...
PostPosted: Thu Mar 12, 2009 11:00 am
A slick damper install tool is really easy to make...
Some 3/4-16 all-thread, a nut and thick washers and damper installs are a snap.
 Post subject: back to the shop
PostPosted: Thu Mar 12, 2009 11:28 am
Thanks everyone...will keep you posted
