It is currently Tue Jun 09, 2026 1:07 pm
PostPosted: Thu Mar 12, 2009 6:58 pm
This is a 78 "peanut" head
The exhaust ports? I smoothed and didn't gasket match. I didn't remove a lot of material.
Intake and exhaust bowls are smoothed and the rough edges were ground off. The exhaust bowls have a hole for the air injection. (it is a 78 California head with a factory block off plate.)
The intake port? So far I have it gasket matched. All smoothed. I didn't take out a bunch of material.
I am thinking I can open up the intakes more than the gaskets. I was going to smooth the intake and not gasket match the manifold on the intake side. I am thinking this will create an anti-reversion effect. I called to find out if the '80 has an air pump.
I was thinking that the exhaust manifold needs to me bigger than the gaskets. Once again to create an anti-revesion effect.
Going to run the stock 1980 solid truck cam, super6 intake, 833OD in a B100 van. Will be using a cat. It is a work truck, I have no idea what he is running for gears.
We are going to mill the head, no idea how much.
The chambers? Polished, I grooved them a little for the flame travel from the plug hole towards the exhaust valve. The valves were unschrouded by radiusing them.
Questions?
Comments?
Criticisms?
I am compiling some pics.
PostPosted: Fri Mar 13, 2009 7:30 am
Do not spend a ton of effort on the ports, more on the bowls and blending into the valve seat. You want exh port to be a bit smaller than the header pipe, from what I know, so don't go much beyond the gasket if at all.
Forget about polishing. It will likely all be covered with carbon and residue after a short time anyway.
If this is a work truck, then maybe mill 0.060" to bump comp a little, but not too much.
PostPosted: Fri Mar 13, 2009 10:54 am
Polishing it over-rated for at home porting. Make it look nice so there is less for the carbon to stick to. Use a gasket as a template, and don't bell shape to it.
PostPosted: Fri Mar 13, 2009 3:24 pm
Yep to the above. Exhaust is still small.
What I don't like is the air injection holes in the exhaust bowl I think he has an air pump. Gotta pass emissions in Nashville.
PostPosted: Tue Mar 17, 2009 6:52 am
Yep, not going for mirror finish.
.060 off the head is figuring I am using a Permatorque Blue head gasket?
I wonder about just reusing the factroy steel gasket. :idea:
Users browsing this forum: Google [Bot] and 7 guests
