It is currently Thu Jun 18, 2026 2:01 am
 Post subject: 198 connecting rods
PostPosted: Sun Mar 15, 2009 8:13 pm
I found a vendor that has new forged H-beam 198 connecting rods. :D
http://www.campbellenterprises.com/slan ... g-rods.php
Matching 225 high compression pistons are also available.
Make sure you're sitting before you look at the prices. :shock:
Ken
PostPosted: Sun Mar 15, 2009 8:31 pm
Yes K1 has worked with us directly to produce those rods. They are actually very reasonably price, maybe not sbc or 302 rods. They had a small problem with the tang location, but great stuff!
 Post subject: Re: 198 connecting rods
PostPosted: Mon Mar 16, 2009 3:18 am
Ken
Stock 198 con rods, used (if you can find them) $200 plus at least $25 (probably more) per rod to add ARP bolts and recondition= $350.
So for less then $150 more you have a much stronger, lighter rod. Actually a no brainer.
PostPosted: Mon Mar 16, 2009 4:26 am
The K1 and Wiesco piston packages need to be a sticky!!
PostPosted: Mon Mar 16, 2009 5:12 am
Or even more, if you REALLY wanted a set, say, 2 years ago... AMHIK.
vm
PostPosted: Mon Mar 16, 2009 5:29 am
I was being conservative. I really think it would be more then $25/rod to uprade the stock ones.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 3 guests
