It is currently Sun Jun 14, 2026 11:40 am
 Post subject: intake question
PostPosted: Sun Mar 15, 2009 1:13 am
Good evening to all,
I took a factory aluminum intake to a machinest today and see if he could make the mods needed to install a supercharger (the one like Al T), and he stated the intake would not hold the pressures of the added boost; he also stated that would have to grind off and the factory seams holding the top and bottom together and then tig weld the top and bottom back together.
The question is does anyone know if this is true or not and does anyone know if there is a one barrel solid aluminum intake out there and where to find one as all I can find a 4 barrel intakes which I have an Offy but I really don't want to cut that one up.
Thanks again for any all support in my quest.
Thanks
Ron
 Post subject: Re: intake question
PostPosted: Sun Mar 15, 2009 3:46 am
It probably wouldn't hold boost very well, seeing as how it is so porous it barely can handle atmospheric pressure. But there were plenty of solid aluminum manifolds made. They are just like the iron ones, just a whole lot lighter. Avoid the welded aluminum manifold.
PostPosted: Sun Mar 15, 2009 7:31 am
You wouldn't know where to find one would you 8) if not would you happen to know a part number and or year they might have been used. for that matter does anyone out there have this info?
Thanks again
PostPosted: Sun Mar 15, 2009 9:23 am
I saw on ebay, that someone is selling intake flanges now. They are steel but if you aren't worried about weight how about a sheet metal intake? It would be alot easier for a do it yourselfer to put together.
Chris'
Autobody
Restoration
Service
PostPosted: Sun Mar 15, 2009 11:04 am
I am almost positive that same guy has aluminum flanges for sale, he has had them before. Best bet would be to contact him.
As far as a cast aluminum intake look around for earlier engines, I believe most of those were not seamed/welded.
PostPosted: Sun Mar 15, 2009 11:35 am
One-piece cast aluminum intakes were used on all 1960 slant-6s, and on the 1976 Feather Duster/Dart Lite. Mopar Performance offered a one-piece cast aluminum 2bbl intake. The 1960 manifolds are the only one-piece cast aluminum factory items without EGR valve provisions.
Seems to me an aftermarket intake such as the Offy 4bbl might also serve as a good base for the type of manifold conversion work you have in mind.
PostPosted: Sun Mar 15, 2009 8:02 pm
Thanks for all the reply's, Stanzilla has stated he might have one if so I'll try and get a hold of it and if not I just I'll try and find one, as a last resort I will just cut up my Offy 4 barrel intake.
Thanks again and if anyones knows where any are please let me know.
Ron
PostPosted: Sun Mar 15, 2009 8:33 pm
Are you using a m90 or m62? If your not in a hurry I'll PM you in a week with an option.
PostPosted: Mon Mar 16, 2009 5:32 am
I'm using a M90 and I'm not in any hurry, and open to any and all advies and help. So please PM, but I will be out of town the next two weeks. I have to go up to Wright Pat Ohio for some training.
Thanks
Ron
PostPosted: Mon Mar 16, 2009 8:59 am
I saw an aluminum intake on a 64-66 Cuda. Factory? Maybe.........
PostPosted: Mon Mar 16, 2009 9:42 am
Nope. See above for factory aluminum intake applications.
Users browsing this forum: Ahrefs [Bot] and 4 guests
