It is currently Tue Nov 17, 2026 11:57 pm
 Post subject: Aircleaner heatshield
PostPosted: Fri Apr 03, 2009 11:43 am
Hi Guys - while I am waiting for the cylinder head - the porting is taking a while - I am sprucing up my engine bay - powder coating and so on - question is - for authenticity the 4bbl snorkel aircleaner - as we had them here - is supposed to be painted black - so now there is this HUGE black heat absorbing area right over the exhaust manifolds - either a heat shield or have the cleaner powder coated bright white?
What do you think?
photo for reference
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Fri Apr 03, 2009 11:47 am
Is that the stock air cleaner? Can you turn it 180 degrees? Can you install a fresh air intake?
PostPosted: Fri Apr 03, 2009 11:52 am
How about orange? That shouldn't be a heat soak color.
PostPosted: Fri Apr 03, 2009 11:57 am
It was the stock cleaner on the last 4bbl slant powerd valiants yes it can turn and fresh air inlet is part of the plan
test on one of them
In the Engine specs - carter 4BBL
Regards,
Fanie Gerber
PostPosted: Fri Apr 03, 2009 3:45 pm
Thats pretty cool, I didn't know they made a factory 4 barrel besides the hyper pack. You could paint the bottom of the lower section silver and leave the side black so it looks stock. Hmm I might try that with mine, its due for some paint.
Grandpa's 1974 Dart Custom 4 door 225 auto, Aluminum Radiator, 1920 Holley.
Users browsing this forum: Amazon [Bot], DuckDuckGo [Bot], Google [Bot] and 4 guests
