It is currently Fri May 08, 2026 5:58 pm
Post new topic  Reply to topic  [ 27 posts ]  Go to page Previous 1 2
 Post subject: ??
PostPosted: Mon Apr 06, 2009 3:52 pm
I took an awe and could actually feel it is down in the head. It doesn't appear to be just a transfer from the gasket? :?: :?:
Thanks,
Rick
PostPosted: Mon Apr 06, 2009 4:29 pm
Rick, I'll go check mine tomorrow and see if its got the same # stamped deal as yours.
I'm almost sure mine has been milled tho, compared to 68 head there is a definite difference of at least 1/16+ in. of the bore going up in the head.
PostPosted: Mon Apr 06, 2009 4:37 pm
I would guess someone stamped it. I have a set of stamps and put all kinds of things in my blocks/heads. :lol:
 Post subject: Hmmm...
PostPosted: Mon Apr 06, 2009 6:48 pm
I know the machine shops around here stamp parts that they work with so they can ID it later if problems arise, or some question about the part occurs... One of my heads is stamped with the initials of the machinist and the amount cut off the head (in this case 080)...
Got pics?
 Post subject: stamps
PostPosted: Mon Apr 06, 2009 7:03 pm
These don't appear to be like the stamps you hit with a hammer. I have those at work also. This is a very fine almost "etching" Once I get it back and check it with a mic I'll know if it was every planed before.
PostPosted: Tue Apr 07, 2009 2:29 pm
So these heads are smaller chambered than the drool plugs? I have a hydraulic one out in the shed (I think!)
Or is a "squishy cam" head a different animal all together?
BTW I am porting a 77 or78 head and I can't help thinking that the exhaust side of the bowls will have some flow problems.
The small blocks have little humps in the port near the flange.
PostPosted: Wed Apr 08, 2009 9:15 pm
Only numbers stamped on the head:
PostPosted: Thu Apr 09, 2009 3:45 am
Those do not appear to be factory stampings. Most likely they were done by the machinist. :?
 Post subject: Cut .100
PostPosted: Fri Apr 10, 2009 2:54 am
Ok,
We got the head back and measured as Charlie mentioned and I got 3.510 from the face to Valve cover rail. It has been cut .100 already. The finely etched numbers had to be done after planing. The mystery is over. :D
Rick
 Post subject: Final Compression Ratio
PostPosted: Sat Apr 11, 2009 2:54 pm
Well as I said the head has been cut .100 I re-checked the cylinder head today before installing it and I cc the top of the block to check the CC's of the eyebrows that are ground at the top of the cylinders. I was pleased to see that with taking the eyebrows into account and the new valve job which did remove some material around the side of the intake valve, the final CR came in at 10.78 instead of 11.2. That will definitely help :D :D
Rick Covalt
PostPosted: Sun Apr 12, 2009 6:11 am
What is the final on the chamber volume?
 Post subject: Final Chamber
PostPosted: Sun Apr 12, 2009 7:39 am
Final on the chamber was 43CC.
Rick
Users browsing this forum: Bing [Bot], Google [Bot], hyper_pak and 17 guests
