It is currently Thu Jul 16, 2026 10:33 pm
Post new topic  Reply to topic  [ 72 posts ]  Go to page 1 2 3 4 5 Next
PostPosted: Mon Apr 06, 2009 1:19 pm
The more I read this site I see more different manifolds having been made for the slant six stock and aftermarket, It would be interesting if someone could make a list of the wide variety made for this fine engine.
Grandpa's 1974 Dart Custom 4 door 225 auto, Aluminum Radiator, 1920 Holley.
PostPosted: Mon Apr 06, 2009 1:50 pm
Dan might have access to the best list, with part numbers but we know there are at least a dozen or more. Here is a shot at a list.......
1. MOPAR M-1 for two barrels
2. The Super Six E-beam
3. Truck version single barrel aluminum
4. Truck version aluminum two barrel
5. Offenhauser 4 barrel
6. Offenhauser dual single barrel
7. Weiand 4 barrel
8. Clifford 4 barrel
9. The HyperPak
10. The Dutra HyperPak
11. Aussie Speed 2 barrel
12. Aussie Hurricane 4 barrel
13. plus all the variations of stock cast iron 1 and two barrel manifolds
14. and maybe some 2 and 4 barrel from South Africa
PostPosted: Mon Apr 06, 2009 1:59 pm
Don't forget the late 60s export/"marine" two barrel intake and the "Lynx" single, double, and triple side draft carb intakes from Oz.
 Post subject: From South Africa
PostPosted: Mon Apr 06, 2009 3:00 pm
Basil Green Atkinsons Power-Pack 2 X 2bbl weber "dual plane" shorty
South african Police Squad Car manifold 2 X 2bbl weber long runner Ram design
Late Model - 78 - 81 CL Regal SE 4BBL for Carter AFB
Prototype "tunnelram" 4BBL for South African Police
For export market - Round 67/68 from Canada - Castiron manifold for BBD
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Mon Apr 06, 2009 4:31 pm
Clifford triple Weber intake
All the Cain stuff. :shock:
PostPosted: Mon Apr 06, 2009 5:04 pm
Pierce triple Weber. This may be the same as the Clifford item.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Mon Apr 06, 2009 5:07 pm
Poser
Did Edelbrock make one once upon a time? I think I read that in Josh Skinner's article.
 Post subject: Re: From South Africa
PostPosted: Mon Apr 06, 2009 5:45 pm
Hey do you happen to have a pic of that one?
PostPosted: Mon Apr 06, 2009 5:49 pm
Clifford Hyperpak (same as the Dutra)
And I think there is a Sissell intake for Webers, just read about that one never seen it.
PostPosted: Mon Apr 06, 2009 6:21 pm
Chrysler-built intakes (not including South African ones 68Barracuda mentions, nor engineering prototypes):
  1. 1960 semipermanent-mold aluminum 1bbl, no PCV
  2. 1960 sandcast aluminum 1bbl, no PCV
  3. 1960-'61 Hyper Pak cast aluminum 4bbl
  4. 1961 cast-iron 1bbl, no PCV
  5. 1961-'64 cast-iron 1bbl, with PCV
  6. 1964-1967 cast-iron 1bbl, with sidedraught carb mount
  7. 1965-'69 cast-iron 1bbl, reinforcement webs between runners
  8. 1965-?? aluminum 2x 1bbl, Argentina
  9. 1967+ cast-iron marine 2bbl
  10. 1967+ cast-iron export 2bbl (probably same as marine)
  11. 1967+ cast-iron Australian-made 2bbl
  12. 1970-'72 cast-iron 1bbl, with large hotbox pocket
  13. 1972 cast-iron 1bbl, with floor jet EGR
  14. 1973+ cast-iron 1bbl, with EGR valve
  15. 1976 sandcast aluminum 1bbl, with EGR valve
  16. 1976-83(?) cast-iron 2bbl, with EGR valve
  17. 1978- EB-welded aluminum 1bbl
  18. 1978- EB-welded aluminum 2bbl
  19. 19??-'?? cast aluminum 1bbl
  20. 19??-'?? cast aluminum 2bbl
Aftermarket intakes (list certainly incomplete):
  1. Dutra-Pak 4bbl
  2. Weiand 4bbl
  3. Offenhauser 4bbl
  4. Offenhauser 2x 1bbl
  5. Warneford 3x SU
  6. Cain 3x SU
  7. Speco 3x SU
  8. Cain 2x SU
  9. Cain 4bbl
  10. Penìn parallel 2bbl (Argentina)
  11. Assorted Clifford hot air manifolds :lol:
  12. Mays 2x 1bbl
  13. 3x Weber (Australian, forget brand)
  14. Speco 2x 1bbl
PostPosted: Mon Apr 06, 2009 6:28 pm
The list is complete with these on there :lol:
PostPosted: Mon Apr 06, 2009 9:08 pm
Will have a look - they apparently did itfirst as an experiment for Naturally aspirated, then used it for a Turbo application which worked quite well
Regards,
Fanie Gerber
PostPosted: Mon Apr 06, 2009 9:24 pm
Redline in Australia make a 4BBL intake, a 3 x Weber intake(could be the one you've mentioned Dan) and a 3 x SU intake. I believe these are the same as the old Cain intakes.
62 Valiant, 225cid Slant 6/PB 904 with lots of good bits
http://www.moparmarket.com/readersrides ... user=SV162
PostPosted: Mon Apr 06, 2009 9:46 pm
There's also a couple of single Weber intakes around, they were made by Lynx and possibly Speco.
Here's a Lynx one.
PostPosted: Tue Apr 07, 2009 7:40 am
Here are some "group photos":
Users browsing this forum: morsim and 2 guests
