It is currently Thu May 28, 2026 6:59 am
Post new topic  Reply to topic  [ 73 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Tue Mar 31, 2009 3:35 am
I'm getting ready to send my weekly "nudge" to Brian...
Doc, Did you have a chance to mock up an engine to check clearances?
When I nudge him again I should have his question answered as to whether or not we want to go with different size valve notches or keep it as is. From your responses it looks like leaving them as is may be the consesus (?).
I will ask the question about piston top thickness at the notches.
He had stated in the other thread what he thought the pistons would hold up to, but that was the other forging. He stated in this thread that the crown thickness would be the same with this new, lighter forging.
PostPosted: Tue Mar 31, 2009 6:26 pm
I may beinterested in a set that is the 100 over.....I have the 45 over in the engine now.....would have gotten the 100 over in the beginning if they were available then......but, all I need is some more $.LOL
Andrew/Kidd
Wife's: 64 Valiant
PostPosted: Thu Apr 02, 2009 4:21 am
PostPosted: Thu Apr 02, 2009 4:36 am
Oops! :shock: I just re-read everyone's posts and it looks like Frank is more interested in the 3.484" size rather than 3.504".
Everyone please chime in so I can go back to Brian with accurate numbers and sizes. Thanks!
Also, those of you who have posted "interest" in these two size pistons let me know if you're "commitedly interested" or "interestedly interested". :lol:
PostPosted: Thu Apr 02, 2009 6:49 am
Look again Ill do both 1 of each. I all ready have a motor at .080 so .084 is gravy.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Thu Apr 02, 2009 7:18 am
Frank
So I should put your down for "ready to order" 1 set of 3.504 and 1 set of 3.484? :shock:
PostPosted: Thu Apr 02, 2009 7:28 am
YUP :D :D :D
Its such an addition
Frank :oops: :oops: :oops: :oops: 8) :lol: :lol: :lol:
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Thu Apr 02, 2009 8:54 am
Car Model: 1962 Lancer 770
Menko, Lou and Jim I assume are just waiting for the green light to place their orders based on posts here and emails.
Yes, I want pistons and will order rods at the same time. Thanks Rob!
MJ
PostPosted: Fri Apr 03, 2009 4:47 pm
are there any piston being consider for the stock 225/ rod, or is everything for the k1 rod package deal?
PostPosted: Fri Apr 03, 2009 8:02 pm
I am a YES,if someone needs,wants my 0.45 ones,mark
PostPosted: Sat Apr 04, 2009 5:36 am
Yes for me on a set, but im about 1 month from knowing which ones.
<img src="http://farm4.static.flickr.com/3173/2992308402_5481afb26e_t.jpg">
 Post subject: I'm still in
PostPosted: Sat Apr 04, 2009 4:20 pm
I am still going to order 1ea. set 3.504, I need some dome machining done, about 20cc reverse dome. I will discuss that with Brian at the time of the order.
I am also going to order the K1 rods at the same time. I am ready anytime Brian is ready to accept orders. Thanks for all your work on this buy, Good Job!!
Thanks Jim
PostPosted: Sun Apr 05, 2009 8:59 am
I am definitely in for a 3.504" bore piston set, and I will also be ordering a new K1 rod set with the narrow big end for cast crank.
PostPosted: Tue Apr 07, 2009 6:32 pm
I am curious, those who are buying the 3.504 pistons, have you done block tests for wall thickness already? Or are you going on faith and hoping for the best? Or...?
Only reason I ask is that reading the articles and various posts on this subject it seems that going this big is somewhat iffy.
I guess what I would like to know is are any of you going this big and not doing any sonic testing, etc?
PostPosted: Tue Apr 07, 2009 6:43 pm
Most blocks will take 0.100" over no problem. I will probably not bother sonic testing mine. Tilley and Jeffrey have routinely done 0.140" over, and Bren did 0.180" over.
If you are worried, just get the 0.080" overs!
