It is currently Sat Jul 18, 2026 11:20 am
 Post subject: Oil Pump Options
PostPosted: Thu Apr 09, 2009 8:42 am
My searches came up nill on this.
Seems that oil pump and/or gear is a weak spot on a high HP engine.
I wanted to know if anyone has a remote pump set-up.
I have been looking into this ever since they had a stock car at my local lumber yard for customer appreciation day.
It had a really impressive external oil pump all plumbed up (dry sump IIRC).
I found an electric oil pump for a turbo set-up on ebay but it could only sustain 30 psi.
Is someone running this type of system?
Any thoughts /ideas on this?
Off to work :( now BBL.
<img src="http://farm4.static.flickr.com/3173/2992308402_5481afb26e_t.jpg">
PostPosted: Thu Apr 09, 2009 9:20 am
There are a number of remote, belt drive oil pumps available, Both wet sump and dry sump. Most of the "hard core" slant racers are using something like this. When you enquire, on pricing, be sitting down. I have a "Peterson" single stage wet sump pump, that I bought froma circle track racer, at a super bargain. When I checked on the price for a new one, it was over $500, then you still need the drive setup. The total cost for a "new" system, would be more then what the rest of my engine cost. They are nice, but pricey.
PostPosted: Thu Apr 09, 2009 12:45 pm
With proper care and set-up, the factory designed oil pump will work fine.
Review the oil pump article for more info.
PostPosted: Thu Apr 09, 2009 5:35 pm
Get the hardened oil pump gear too! it's most likely in the article!
 Post subject: No Brainer!
PostPosted: Thu Apr 09, 2009 6:18 pm
Poser
Stone, order a blue printed pump from Doc. Hardened gear - passages massaged. Give him the specs and he will set the pressures. Easy peasy, lemon squeesy!
PostPosted: Thu Apr 09, 2009 6:52 pm
I do plan on doing the blueprinting and getting a hardened gear- It was more out of curiosity to see what has been successfully done.
I have never heard mention of any one using a wet/dry sump external/remote pump systems on a slant.
As Charrlie S said there are some hardcore racers use these.
Do these hard core racers own cameras?
:lol:
PostPosted: Thu Apr 09, 2009 7:23 pm
The fastest Valiant in the country had a stock oil pump on it. :shock:
PostPosted: Thu Apr 09, 2009 7:47 pm
I think Ron Hamby Runs an external setup.. I just remember the right side of the engine block being real smooth - No Distributor - No fuel pump - No oil pump.
PostPosted: Thu Apr 09, 2009 8:12 pm
Last time I saw Ron's car he had a belt driven pump on it. Cox boys had a dry sump, and the green 5 speed car had I believe a wet sump but multi stage pump. :shock:
 Post subject: Seymour
PostPosted: Sun Apr 12, 2009 7:54 am
Seymour has an external pump and did an article on it with pictures in one of the SSRN a while back. I'm sure someone will give you the right SSRN number.
Rick
