It is currently Thu Nov 05, 2026 1:53 pm
PostPosted: Mon Apr 13, 2009 6:21 am
My "new" 66 Dart 270 SW has NO fuel gauge reading when full. Then when it has about 1/4 tank VOLIA it starts going up, it will go up to about 1/3 tank then it starts towards empty again.
Any ideas?
Thanks,
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Mon Apr 13, 2009 6:25 am
Float arm bent in wrong position?
PostPosted: Mon Apr 13, 2009 8:09 am
I would take the sender out and clean it.
If the car sat for a long time, the old gas forms varnish on everything.
My guess is that the 1/4 - 1/3 area is the only place it's making contact through the sconge.
Make sure the sender gets a good ground when you put it back in.
O==\=/==O
"A mechanic is Somebody."
- Jim Preston
PostPosted: Mon Apr 13, 2009 8:54 am
And make sure the float doesn't have any holes in it.
PostPosted: Mon Apr 13, 2009 10:32 am
PostPosted: Mon Apr 13, 2009 2:06 pm
Thanks for the suggestions now if it will just stop raining.
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Mon Apr 13, 2009 2:30 pm
sometimes the foam float arms can get holes in them and swell up causing the arm to not float properly. I'de drop the tank and check the arm. make sure its still pretty light. if its got more weight than it should ide replace it.
-- Mister Perkins --
Pictures of my truck
http://www.cardomain.com/ride/3257131p
Users browsing this forum: Amazon [Bot], Google [Bot] and 1 guest
