It is currently Mon Nov 09, 2026 3:33 pm
PostPosted: Thu Apr 23, 2009 10:24 pm
so its my 73 swinger with a 225 /6 and 904 from a 71 valiant. i got a new starter. and every once in awhile i'll go to start the engine and the starter will just click. to get the car started i have to manually turn the engine over. but its picky. i have to get in the right spot then it will start. any ideas?
PostPosted: Thu Apr 23, 2009 10:26 pm
Is it the starter that clicks, or is it the starter relay that clicks? Is this really a new starter, or is it a "remanufactured" unit from a parts store?
PostPosted: Thu Apr 23, 2009 11:00 pm
it's a new starter. it seems as if the starter doesn't have enough strength to turn the engine over until i get it in a good spot then it has no problem.
PostPosted: Thu Apr 23, 2009 11:05 pm
Are you really sure it's actually a new starter? Where did you buy it, and under what brand name?
PostPosted: Thu Apr 23, 2009 11:17 pm
the brand is reman and i bought it from kragens. they asked if i wanted it new or re manufactured and i went with the new one. i had it tested too.
PostPosted: Thu Apr 23, 2009 11:22 pm
"Reman" is not a brand, it is slang for "remanufactured". You cannot buy a new starter for this application at a parts store. I'm afraid either the counterman at Kragen wasn't clear (deliberately or unintentionally) or you misunderstood him.
Remanufactured parts tend to be junk, no matter how fancy the box they come in or the warranty certificate they come with. The most likely culprit is a bad starter. You'll keep on having the same problem if you keep on buying "reman" parts. You will do better to visit a wrecking yard near you and buy a good used starter from a 1990 to 2000 Dodge truck or van with 3.9, 5.2, or 5.9 engine. It's a compact high-power mini starter that will spin the engine much faster and more quietly than the old starter.
PostPosted: Thu Apr 23, 2009 11:54 pm
reman. it make sense now i don't know why i didn't see it before, damn i feel stupid. thanks for the info i'll definitely go pick one of those up.
PostPosted: Sun May 03, 2009 5:18 pm
A new mid 90's dodge truck /van starter is offered for $100 in EBAY under number 220223255163. Is this the same as the mini starter Dan recommended?
PostPosted: Sun May 03, 2009 5:24 pm
Not this either, It is knock off junk sold as geniune starter which is not. Be careful on ebay.
Cheers, Wizard
PostPosted: Sun May 03, 2009 6:18 pm
here's the LINK if y'all want an easy look.
regards,Rod :D
