It is currently Mon Jun 01, 2026 5:42 pm
 Post subject: Water Pump Info Needed
PostPosted: Mon Apr 27, 2009 5:14 pm
So the other night, I was drifting to sleep and ordered some parts from rockauto. Needed a new water punp, well saw a decent price and ordered one. THEN i realized it was ACDelco.
Shoudl I return for a different pump? I know ACDelco is a GM company, who has the best waterpump..dont wanna be taking it apart again next spring. thanks alot
PostPosted: Mon Apr 27, 2009 5:22 pm
The local farm store used to carry all AC Delco products; fuel pumps oil filters waterpumps etc and back THEN they were a decent product; nowadays its probably "reboxed" Cardone; reman garbage.
PostPosted: Mon Apr 27, 2009 6:14 pm
ACDelco was renamed to "Delphi" a little while back, at least for actual GM parts and various other accessories they make now. I haven't had any issues with ACDelco or Delphi parts in anything I work on.
~THOR~
PostPosted: Tue Apr 28, 2009 4:06 am
You still need to check where the part was made. AC Delco is outsourcing some of their manufacturing to China. This fact was brought up at a AC Delco seminar, I attended last year. Also AC Delco has sold the rights to their name to other companies, for certain products, and has relinquested control, of the product (flashlight batteries, for one).
PostPosted: Thu Apr 30, 2009 12:19 am
Ah... that figures..
~THOR~
PostPosted: Sat May 02, 2009 10:01 am
The water pump came today.
ACDelco Brand
MADE IN CHINA (shocker..)
I also ordered a felpro gasket for the waterpump, The gasket with the ACDelco is much thicker around the edges. (wider area is covered)
Should i send this pump back to the guys at rockauto?
What pump is most dependable to use?>
THANKS!!!!
PostPosted: Sat May 02, 2009 10:36 am
Good luck finding one not made in China, no matter whose name is on the box.
PostPosted: Sat May 02, 2009 11:16 am
just did some digging and found that the water pump NAPA sells is made by GATES
I heard they are a g ood company, should I use this one VS ACDelco?
PostPosted: Sat May 02, 2009 3:08 pm
Ill let you know on Monday if the NAPA is China made as I have one on the way.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sat May 02, 2009 6:45 pm
Nope. Gates doesn't make water pumps, and never has. Neither does AC-Delco. They buy them — almost entirely from China and similar countries — and box and sell them.
They make excellent belts and hoses. They do not make water pumps, thermostats, or any of the other non-belt-non-hose stuff they sell.
PostPosted: Sun May 03, 2009 5:10 am
Dan
Is Gates still making NAPA's belts and hoses? My local operator says they are???
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sun May 03, 2009 6:58 am
I don't know; never been much of a "napa fan" but I know that Gates is who supplies Car Quest.
but lately, I've replaced all the hoses on my D 250, and (2) Wranglers and wound up going with Dayco products; I've used both brands interchangably over the years with good results.
but the Goodyears sold by Useless Zone have not held up as well for me; especially bypass hoses on smallblocks; the uppers/lowers don't seem to be "as bad" as the bypass hoses, or their molded curved heater hoses, which are also a "last resort" buy in that brand.
when OE ones last upwards of 10 yars and were replaced as a matter of maintenannce, rather than because of an actual problem, the replacements blow in 1-1/2 years, leaving you on the side of the road.
PostPosted: Sun May 03, 2009 9:24 am
I had to quit trying to like Dayco's "Top Cog" belts.
