It is currently Thu Dec 25, 2025 10:47 pm
 Post subject: bolt pattern d150
PostPosted: Thu May 07, 2009 2:56 pm
Does anyone know what the bolt pattern is for my d150? is it 5x5.5?
-- Mister Perkins --
Pictures of my truck
http://www.cardomain.com/ride/3257131p
PostPosted: Thu May 07, 2009 3:36 pm
Pre-86, 5x4.5 86-up, 5x5.5. What year is yours?
PostPosted: Fri May 08, 2009 1:52 pm
sorry. never mind. I forgot my truck had the tag in the door jam. My truck is an 87 8)
I'm pretty sure it is 5x5.5 though. Weird
PostPosted: Fri May 08, 2009 9:38 pm
You have a 5 x 5.5 bolt pattern. 86 up Dodge trucks and vans, Ford 1/2 ton pickups and vans going back to the early 70s, Jeeps, and a few others have used this bolt pattern. On my 84 Ford 1/2 ton van I am running a set of original Jeep slotted mags. You should have a wide range of rim choices.
The 5 x 6.5 in the door jam is actually "15 x 6.5", the factory original rim size. The "1" on the 15 was printed on the black space of your label.
PostPosted: Fri May 15, 2009 10:10 am
Yup, lots of tire and rim options. My truck is 84 and for a spare tire I used a tire/rim from a Ford Ranger. For 86 and newer I think the Jeep rims would look cool, but the newer Rams will not fit properly IIRC. Even if they do, they'd look like crap IMO.
