It is currently Sun Nov 22, 2026 10:43 pm
Post new topic  Reply to topic  [ 293 posts ]  Go to page Previous 1 … 16 17 18 19 20 Next
PostPosted: Thu May 14, 2009 5:51 am
don`t let anyone talk you into a v8, if you order the cam with a 4degs adv built in then instill it at 0 degs, but still deg the cam with a deg wheel to get the center line right. the rear main seal from summit should be the rubber one , it will work just stagger it about a 1/4in of center when installed so that the two half will line up just above and below the cap joining seem, this will prevent leaks.
PostPosted: Thu May 14, 2009 6:51 am
ok! great help, thanks. I guess I did not tell anything about 4 deg advance. hmm
PostPosted: Thu May 14, 2009 12:15 pm
if you didn`t ask they most likely machined it with no advance, just check it when you dial in the cam install center line.
PostPosted: Tue Jun 09, 2009 11:00 am
Site Admin
Just got off the phone with John. They finally secured a small shipment of slant six cores.
They are hoping to start grinding back-ordered cams early next week! :D
CJ
PostPosted: Thu Jun 11, 2009 10:33 am
D@mn and I should have my oregon cam by friday, ah well I have good thing about oregon cams, but then again Erson has a sweet topend package deal..............
-Mike
PostPosted: Fri Jun 12, 2009 12:35 am
What's a good cam to go with a supersix and everything else fairly stock? low-mid range power and torque with a smooth idle:)
it's not for racing, I just want a few extra ponies while I putter around town.
PostPosted: Fri Jun 12, 2009 6:53 am
For those who have ALLREADY ordered a cam they should ship next week. For those who have not they wont have a big run of blanks until July 27th.
However if you have a used cam in good shape Erson will regrind to any of the profiles. This is less than the cost of a new cam and ther is NO wait. John is talking to the powers that be about OUR cost.
Ill update when he calls me,
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Mon Jun 15, 2009 4:37 pm
Recomendations on a cam for a completely stock engine? Possible headers and 4 barrel in the future.
To each his own (so what if I wanna build a 450 horse MPFI turbo /6 instead of using a V-8!)
PostPosted: Tue Jun 16, 2009 5:40 am
RV 12RDP or ERSON 270 for a stock engine.
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue Jun 16, 2009 8:59 am
Is there any way to get a catalog of custom lobes by Erson? Or any online source for grind info? I'm not certain of my direction just yet but I spec my own cams and I'd rather see what they have rather than sit on teh phone for an hour.
PostPosted: Wed Jun 17, 2009 6:43 am
Moper
I havent had any luck in getting any info except via phone. Sorry,
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Wed Jun 17, 2009 8:13 am
http://www.mrgasket.com/ftp/pdf/erson.pdf
I am not sure if this offers what you are looking for or not.
PostPosted: Wed Jun 17, 2009 10:55 am
Looking at Erson's mechanical lobe profiles on page 95 of that pdf I don't see many lobes in the duration range I'd expect for a hot slant. They go right from a mild 220° at .050" tappet rise to the moderate 230° and then right to 242°, 246 and 254. Oregon Cam Grinding has a lot more profiles in the 220-240° @ .050" lift range.
PostPosted: Thu Jun 18, 2009 6:21 am
Josh I agree. I just ordered a big cam and had to shift things around several times. The cam ended up a little bigger than I wanted.
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Mon Jul 27, 2009 4:36 pm
I just ordered a RV15RDP and they are out of blanks but are supposed to be getting some in. I talked with John Hartman, he seemed like a real nice guy. He didn't really want to sell me one til they had the blanks. I told him I won't see the states until 8-21 anyway besides I am just getting parts while I have the money. I told him I was in no hurry, just go ahead and order it up.
Thanks Mike
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot], Google [Bot] and 10 guests
