It is currently Mon Nov 23, 2026 9:43 pm
PostPosted: Sat Jun 13, 2009 12:03 pm
Did your cam bearing spin??
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sat Jun 13, 2009 3:58 pm
I was beginning to wonder. I wouldn't know how to check without major dissassembly? Gmac
PostPosted: Tue Jun 16, 2009 7:41 pm
This sounding all too familiar! Same problem, no oil to rockers. New short block, and a bunch of other EXPENSIVE stuff!
Cam manufacturer says "not the cam oiling holes".
Other experts say "has to be".
Some people say, "use a high volume oil pump".
Some say groove #4 cam bearing...
Others say you will lose oil pressure if you do. Stiil others say "NO". Some say the rear rocker bolt should have a different size shank, others say no is does not??
Good god, does anybody have an answer? I just want to put the motor back in the car and drive! This is not a high tech build just a built slant six for the street.
PostPosted: Tue Jun 16, 2009 9:44 pm
If the engine is out of the car.. just groove the rear cam bearing or rear cam jounal and it will oil the rockers.
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 6 guests
