It is currently Tue Nov 24, 2026 12:15 pm
Post new topic  Reply to topic  [ 18 posts ]  Go to page Previous 1 2
PostPosted: Sat Jun 13, 2009 4:28 pm
I currently have an '85 2wd ram with hydraulic lifters. we checked compression and #3 cylinder is dead 0 cylinder pressure, burnt or bent valve I am assuming. I also have a mechanical lifter head, and lifters. Am I able to put the mechanical head onto the long block using the Hydraulic Camshaft/mechanical head? or will this not work? I'd rather not have to pull the engine/change cams yet, as this is a work truck we need to use soon. Thanks
Ryan Covalt
PostPosted: Sun Jun 14, 2009 7:13 am
RC
Have you pulled the valve cover off yet? You may have a bent or ?? push rod. Might be worth a look.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sun Jun 14, 2009 12:11 pm
Frank, I did pull the valve cover off, and the pushrods appeared to be straight. The valves also appeared to be opening and closing the entire as much as I could tell from the top. Everything appeared to be moving like it should from what I could tell. I was hoping I had a bent pushrod, but I dont think I got so lucky. I would like to build another big valve mechanical lifter head anyway, but I didn't want to pull the engine and change camshafts yet, because it is a work truck, and I want to get it back together as soon as I can.
Ryan
Ryan Covalt
