It is currently Sat May 02, 2026 1:31 am
 Post subject: Another stupid question
PostPosted: Tue Jun 30, 2009 3:53 pm
Poser
Okay racer guys, how do the tractor pullers and the nostalgia drag racers couple two engines together? Could I put two slants together and do it in a way that could be half a$$ streetable? I am hot rodding an old pick up and going to create a custom frame anyway. I know that this will more than double my engine costs but would it quadruple the headaches? If I could pull it off it would be quite a slantable moment! What do you guys think?
PostPosted: Tue Jun 30, 2009 4:15 pm
You can couple two motors through a 4x4 transfer case.
motor#1 drives through the trans to the transfer case in the normal fashion. Motor #2 drives through the trans to the front tranfer case output. (normally for the front driveshaft.
PostPosted: Tue Jun 30, 2009 4:53 pm
I'm a bit confused, you looking to use two engines to drive a custom truck? In what arrangement?
1973 Plymouth Valiant
1953 Dodge Panel
PostPosted: Tue Jun 30, 2009 6:25 pm
Poser
Sandy, thanks for the reply but you may have to draw me a picture! :oops: Slant6 wonder, two slants linked in-line crank to crank, one in front of the other dumping through one transmission. Yes, I need therapy!
PostPosted: Tue Jun 30, 2009 7:00 pm
Car Model: 1967 Dodge Dart GT
hmmmm....slant 12....i feel like someone said something about that on here before...but i cant find it...let me know, i want to watch! and i can help wrench a little, i think youre the only indy slanter i havent met yet!
PostPosted: Tue Jun 30, 2009 7:37 pm
You could make a coupler and join them crank flange to damper.
It would be different. :shock:
PostPosted: Wed Jul 01, 2009 4:02 pm
Site Admin
Wasn't there a dragster set up with two slants back in the late 60's?
CJ
PostPosted: Wed Jul 01, 2009 5:41 pm
CJ
Don't know about Slants, but twin engine dragsters used to be very popular before blowers got really big. Eddie Hill, The Freight Train, Bean Bandits, TV Tommy Ivo. Ivo even ran a 4 motor car for a while.
Hill's had 2 Pontiac motors that meshed at the flywheel ring gears. He blew a flywheel at Indy and almost killed some people.
Buddy of mine tried running 2 BB Chevies on nitrous in T/AD in the 80's. He was not successful. :shock:
PostPosted: Wed Jul 01, 2009 6:29 pm
Couplings- http://www.brancekrachy.com/catalog/ind ... -Couplings
Knock yerself out :D
PostPosted: Wed Jul 01, 2009 7:19 pm
Poser
Thanks guys for you interest and help. Came across a picture of slingshot dragster with two Chevy sixes and that has been stuck in my brain ever since. My pick up project will be highly modified and hopefully have a sixties drag racing vibe. I know there are guys who do nostalgia drag racing who are on the H.A.M.B so I will probably pose the same question over there. Maybe I can find someone who is currently doing this to see if it is actually feasable or quite possibly a mechanical nightmare!
