It is currently Thu Apr 30, 2026 9:52 am
Post new topic  Reply to topic  [ 30 posts ]  Go to page Previous 1 2
PostPosted: Tue Jul 28, 2009 9:37 pm
When I originally posted about this I had forgotten about all the work James Jaggers had done. In the mean time I hit water when attempting to offset my intake ports. I'll likely fix my head, but will probably forgo the testing.
PostPosted: Wed Jul 29, 2009 6:50 am
Josh
Is this work posted somewhere??? Can we get a copy?
Thanks,
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Wed Jul 29, 2009 7:27 am
Who has used the MP porting templates?
I enjoy porting and polishing.
Anyone think unshrouding stock valves will help economy?
'72 Duster 198 stock cam, 3:23's Hookers on jack stands for 8 years in the driveway
'79 Maxivan 360 Offy Qjet Comp RV cam/rusting in the driveway.
93 D350 160HP Cummins Auto :-( Dually Clubcab needs a injector pump
2005 Golden Couch Buick
PostPosted: Wed Jul 29, 2009 8:22 pm
I have never seen any for the slant six. Can you point me to them?
PostPosted: Wed Jul 29, 2009 9:42 pm
They are in the MP book for the 6's page #279
PostPosted: Thu Jul 30, 2009 4:27 am
Is this the MP parts book, or the racing manual?
PostPosted: Thu Jul 30, 2009 5:38 am
racing manual
PostPosted: Thu Jul 30, 2009 8:10 am
racing manual
I have 4 racing manuals (different years), looked in all of them and still can't find "templates", There are sketckes of the port, but no actual templates. Mopar used to sell a plastic sheet with templates printed on it, for the V-8"s. You would cut the template of of the sheet, and use it as a guage, in the post to guid your grinding. I have never seen one for the slant.
PostPosted: Thu Jul 30, 2009 8:26 am
Josh, If you can wait awhile you could run you test of the more built heads with and w/o the hurricane intake as well. Intakes can hamper intake flow as well. I will see if I can find my flow sheet for my head. I am running 1.72I/1.50E chevy's. I dont know for sure but altitude is 2800 feet or so. I got 195 cfm at .650 ant 200 with no valve. Josh what is your elivation? I'll see if I can free some cash for you as well.
it's like a vw, sounds like a million miles an hour but goes really slow. (for now)
PostPosted: Thu Jul 30, 2009 8:43 am
did I read this right..the testing is off for now?? If not I'll help what I can.....Recipes for a /6 build seem hard to come by this would help alot...count me in
Ha Ha...this could be alot of fun :lol:
Its so nice out side, I think I'll go lay under my car..
PostPosted: Thu Jul 30, 2009 12:21 pm
racing manual
That's all it is. It's a sketch of the port. Ihave never seen templates so I assumned that you cut them out and placed them in the runner. :wink:
 Post subject: re;
PostPosted: Thu Jul 30, 2009 1:00 pm
i wonder if anyone has tried checking flow of head with intake attached and ported to obtain same flow through all 6 runners to even out flow between runners with intake manifold attached. have also heard of some guys welding a piece of 1/4 inch square aluminum in the intake around the 3 and 4 cylinder runner area to help equalize flow.
 Post subject: Re: re;
PostPosted: Thu Jul 30, 2009 4:21 pm
I think there is a diagram of that in the archives here.
PostPosted: Thu Jul 30, 2009 7:11 pm
[quote="Rug_Trucker"]They are in the MP book for the 6's page #279[/quote]
Rug I have the MP 6cil. book and I can't find anywere in the text next to the ports sketch that states they are "Performace Temples" it only says that they are a "typical Intake and Exhaust port layout" and (maybe I'm wrong) but I allways have thought that those drawins were of stock ports and not performance ports templates.
As I said, maybe I'm wrong... I don't have the book here to double check, but this is what I remenber.
Martin
Martin Zappettini
1974 Dodge Polara RT 318cu.
1965 Valiant III Coronado Slant Six 6-Pack (soon!!)
PostPosted: Thu Jul 30, 2009 8:16 pm
I've never cut them out and checked them in the ports.
Never crosses my mind when I'm grinding on a head :P
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Rob Simmons and 1 guest
