It is currently Thu Apr 23, 2026 11:30 am
 Post subject: Brakes ID
PostPosted: Mon Aug 03, 2009 11:27 pm
I have a 71 Duster that has been converted to front disc brakes (5x4.5 bolt circle) and was told that it was from a 73 Duster. How can I verify this and what parts would have been changed out for the conversion (steering knuckle, control arms, brake hoses, etc)? Thanks.
"You know a car is really yours when you've touched every fastener on it." -David Freiburger
PostPosted: Tue Aug 04, 2009 5:02 am
That would make sense. The older than 73 disc were K-H 4 piston disc with the small 4" bolt pattern SBP. 73-76 A body are all pretty much interchangeable and were LBP 4.5.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue Aug 04, 2009 1:01 pm
So when ordering ball joints, control arm bushings, pads, etc. I should order them for a 73 to 76 A body?
PostPosted: Tue Aug 04, 2009 6:00 pm
If your stuff is from a 73 Duster, order for 73-76 A body
Your upper control arms were changed, but the upper control arm bushings are the same for all years. Upper Ball joints are larger for 73-76.
Your spindles were changed, so the lower ball joints are larger and from 73-76.
Tie rod ends are same for all A bodies, if I'm not mistaken. You can upgrade easily to the larger HD style 11/16" instead of 9/16" tie rod ends and sleeves. The part #'s are:
MOOG
ES440S SLEEVE x 2
ES352R TIE ROD x 2
ES355RL TIE ROD x 2
Lower Control arm bushings are the same all years.
Strut rod bushings: there are a few different types, I would just order for '71 since that is the K frame you have. Maybe someone else can correct me on this or any other mistake I have made here. There is a lot of information on here, so poke around. Good luck with the rebuild. I recommend RockAuto.com for parts, they have good prices.
Rotors, Pads, Calipers, hoses, are all late model 73-76 if the swap was done correctly. Ditto for the master cylinder and proportioning valve.
PostPosted: Tue Aug 04, 2009 6:46 pm
Thank you for pointing me in the right direction :D
